Computerized carb
I bought a new carburetor from national confirmed with the staff from national and they said the one I was looking at was in fact the one I needed I’ll attach a picture of the one I purchased. Installed turned it on and ran fine. Now 2 weeks later it’ll crank but won’t fire up opened up the choke flap to see if there was any gas but nothing. I have never ran a compression test on the engine I’m not too sure how you do that. As far as the distributor do I check for vacuum or what exactly do you mean? I’m super new to this so my apologies on million questions.
Okay I'm understanding more,so you put the correct replacement carb on,not a non ccc carb. I thought you already swapped and were trying to make it work. Okay take the big vent hose off the front of the carb it is in the very front up high bigger than pencil in diameter. Now take the lid off the air cleaner there is another big nipple with nothing on it,through that nipple fill the carb with gasoline, use a dish soap bottle, until it starts to dribble out the vent nipple. Does the truck start and run until it runs out of gas? Read post here for pics.
iservin619
san diego ca
Ivan
GMC sierra
350 small block
Okay I'm understanding more,so you put the correct replacement carb on,not a non ccc carb. I thought you already swapped and were trying to make it work. Okay take the big vent hose off the front of the carb itbis in the very front up high bigger than bpencil in diameter. Now take the lid off the air cleaner there is another big nipple with nothing on it,through that nipple fill the carb with gasoline, use a dish soap bottle, until it starts to dribble out the vent nipple. Does the truck start and run until it runs out of gas? Read post here for pics.
I will give it a shot tomorrow and let you know how it goes. Thank you
thatgermanguy
