Factory tach wire hole in firwall
the 77
Newport News, Va
Michael
1977 & 1982
does anyone know where to drill the hole in the firewall to run the wire for tach harness? It's an aftermarket harness with a grommet to run through the firewall.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Just run it through the regular hole by the bulkhead.
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
Well, that's up to you. I generally look for an exhausting hole that was put there by the factory to feed wires or linkages through the firewall. The the tach wire and be inserted through the existing hole. Wiring harness, steering shaft, throttle, etc. A drill works, or even a punch and sledge hammer. Other times, I just blast a random hold using a bullet, which is probably the quickest way to get the job done.
the 77
Newport News, Va
Michael
1977 & 1982
Was just trying to make it look factory.
thatgermanguy
