Will a 8.5 Camaro 10 bolt axle fit in a 1981 squarebody?
Ryanbrown36
Ontario, Canada
Ryan
c1500
Might be a stupid question but I have no clue about rear ends. I have found a 1970 8.5” Camaro 10 bolt with 4.11 gears and was wondering if I can make it fit in my 1981 sierra. Thanks
Strick
Dunn, NC
Harold
C20 Crew
The center section will work but it is or should be 28 spline where the trucks have 30 spline axle/spider gears. If it is a limited slip then I'd recommend to purchase a new unit and gears and go that direction.
HS
Ryanbrown36
Ontario, Canada
Ryan
c1500
HS
It is a posi rear end, which is the main reason I would like to swap mine out, I currently have a non posi 3.08 in it now. My main concern was the overall length of the axle?
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
Is your truck a 4x4? If so, that axle wont work unless you swap the front axle as well.
The gearing will be different, so keep that in mind. I believe that the 4.11 gearing would give a lower top speed.
If the length of the axle is wrong, you can use wheel spacers or different wheel offsets to compensate.
Ryanbrown36
Ontario, Canada
Ryan
c1500
The truck is not 4 wheel drive and believe the length of the axle is 56” backing plate to backing plate. Not too worried about top speed more about how bad the mileage would be highway driving, but also want a it to be fun to drive around town so understand it’s give and take for that aspect. So from what I understand it wouldn’t work without changing the diff to a 30 spline?
Edelbrock
Senior Member
Earth
Grumba
K5 Blazer
If you are replacing the entire axle, I don't see how splines would matter. As long as the drive shaft will bolt up to the U-joint, then what difference would the splines make? Note: I am no axle expert by any means.
Strick
Dunn, NC
Harold
C20 Crew
The length overall is different as well as the spring perches being below the tubes instead of above. There are no shock saddle/perches on those F body axles either as they go into the U bolt pad. The center section and gears MAY work as long as the spiders are the same spline. I just did lockers and gears on my 87 and those 10 bolts are 30 spline. I have a Yukon unit and gears for my 72 Camaro and they are 28; that's why I was mentioning the spline difference as the entire axle will not work.
HS
Ryanbrown36
Ontario, Canada
Ryan
c1500
Okay, appreciate the help
Ryanbrown36
Ontario, Canada
Ryan
c1500
HS
I would prefer relatively easy swap if possible which seems like this might be a decent bit of work to do, would your recommend not using this axle due to the differences or is it worth a shot considering it’s a good deal and can’t find any truck axles around me?
legopnuematic
Licensed Junk Dealer
MO
Spencer
A Camaro should be a 5x4.75 bolt pattern, a 2wd 1/2 ton is 5x5 bolt pattern.
Meaning you need different wheels for the rear, or change (or redrill) axles or run adapters.
In my opinion, you’d be far better off to find a reputable person to install new gears/posi in your current 10 bolt, instead of swapping one from a car in. Spring perches, shock mounts, etc also will need to be changed.
Or find a 10 bolt from a squarebody that has what you want, then swap the whole assembly.
Ryanbrown36
Ontario, Canada
Ryan
c1500
Ok appreciate the help, definitely seems like a better option right now
77Dmax
vt
Joe
The 8.5 diff didn't come out until 71, and chevy was pretty slow to give up on their 8.2. I would make damn sure its actually an 8.5 rear. Lots of things happen to these cars in 50 years. It would be a good donor for parts
77Dmax
vt
Joe
HS
The spline change was a year thing, not car vs truck. All 8.5 axles were 28 spline into 87, beyond that they all went to 30 spline.
This^^^ and the one above it^^^If it is an 8.5 10 bolt,which it should not be,by application. Rob the ring,pinion and posi diff out if it.A GM,8.5 diff is a GM 8.5 diff, diff and gear set are the same car or truck. Most obvious identifier is the lugs cast into the housing at 5 and 7. Look and see if the Camaro rearend has bumps that match your rearend at 5 and 7 at the pumpkin cover.
Ryanbrown36
Ontario, Canada
Ryan
c1500
For some reason that idea never crossed my mind, it does look just like my rear end. These are photos of the Camaro rear end here
unimogguy
