3 minute battery life…?
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
The battery ends of both cables are clean, shiny, and bare. I usually run a Group 78, and use charging lugs as the battery cable bolts. Much easier to clup an in bed sprayer pump to than normal side terminal bolts. Now, tbh, I cannot remember when I last changed out the negative cable, the one that got so hot, so fast. Cables are cheap, will start there.
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
Starting to think an LS swap is the answer here :shrug:
Will load it into the crusher and push the button myself before it gets any kind of fuel injected engine…
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
the dexcool is only an issue if your heater core and radiator are old brass/copper type
I assume the heater core is probably but a replacement radiator might not be
Stock heater core, aluminum/plastic radiator. Just like the one that popped an end tank seam. 2017ish radiator hoses, heater hoses might be originals.
olnick
Milford NH
Nick
c15
1982 350 4 bolt mains
If the battery terminal was welding HOT cut the cable back and install a New clamp on terminal. The weakest point in a circuit will become the hottest when attempting to draw a large amount of current through it. Check the voltage from the battery terminal to the rear of the alternator when trying to start. it should be no more than .1-.7 volts. This is assuming that the terminal that got hot was the positive one.
Olnick
All of this except for post 7 is assuming the engine turns freely. Pull the plugs and turn it over by hand. Does it turn free?
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
Yes, turns freely with the plugs out. Can lay under it and turn it via the crankshaft pulley. Air pump belt is removed.
Scruffy49
Rosemark TN
Jeff
C10 swb
4.3L
Olnick
Positive cable end was cold, negative cable end was sizzling hot.
tball67
