Lookin for a replacement style mirror
nathanielbenitez
livingston tx
nathaniel
c30
Ok so I just bought this truck and it has no mirrors and these are the oem bolt holes the passenger side mirror was apparently ripped off the door and it is bent pretty good it ripped the riv nuts out. Looking for a similar mirror with the same mounting brackets thanks
straydog371
WNY
Kerry
I've been trying to find a vendor for OEM style towing mirrors too...thanks for that link! I ordered 2 from them and will post pics when they arrive.
Been driving around with just one original side mirror and it's on it's last legs...glass is loose and has a small crack.
nathanielbenitez
livingston tx
nathaniel
c30
Are those mirrors any good for towing? say like a 20ft gooseneck
Auburn, Washington
So being a dually it had one of 2 original style towing mirrors probably the smaller frame mount ones like the brown truck above.
But the mounts on the top of the door mean someone put Cali mirrors or semi truck mirrors on it. (Whatever they’re called.) Not OE.
That one door looks thrashed, so pick your poison or match the other door and replacement door if you’re replacing it?
straydog371
WNY
Kerry
I'd say they'll be ok for occasional towing.
I believe the RPO code "DG4" on my SPID decodes as "mirror, west coast type, small".
Grit dog: I assumed this was the OEM mount setup for my truck?
probably that same mirror, except instead of that connection to the mirror, it would be the rod poking into the housing of the mirror , with a fatter back
See how its flat? this is a painted one
straydog371
WNY
Kerry
You are correct.
My passenger side mirror was broke so I purchased an aftermarket set (link in post#2 above). They attach to the door mounts different but will function just fine.
I haven't swapped the drivers side mirror yet, no need to unless the original breaks. Only us squarebody enthusiasts will notice the subtle difference huh? :cool:
You are correct.
I ran into a detail **** on discord server ... they were so excited to find the swing out mirrors , the ones which have the large 4 point bracket to the door and hang lower but flip in and out wider
Like these
I found him , easily, a new set online to replace the ones that originally were on his truck
And as soon as he noticed the hinge difference, he threw the towel in , said no, and then became grumpy that its a "fake"
I was like... o_O:33:
jlyon1006
