Finally got a running 65 C10
1low4x4
Nick
went to walgreens for a battery for my digital caliper so I could measure the od of the valve stems to buy the correct seals, both of my digital calipers were acting up so threw them away, run to autozone, convince the kid working there that there is such a digital device that I'm describing, found one on the shelf, got home, measured the stems, ordered the seals.
My stepdad keeps trying to insist I stick a 350 that he has in the truck, says its a fresh rebuild. What would yall do? I kinda like my little 283/305 and it already has my cam in it, I guess I could pull the cam out and stick it in the 350...
16 year old me would have said "350 is bigger, I want that!". But modern day me would say "I've got this nice little 283 that I've put work into, I'll stick with the nice little 283".
Carb'ed Vortec 350
yes....I hope I can get it back together once I get the needle bearings I need
Right on. Did you get the entire rebuild kit, or just part by part? I'd have to look, but there is a place in Washington state that sells rebuild kits for the 3 speeds and 4 speeds, and they come with all the seals, synchros, bearings, bushings, etc.
Carb'ed Vortec 350
I'd stick with the 283, it'll run just fine.
1low4x4
Nick
I bought a full kit but I'm not going to use it, just the seals and gaskets and bearings I need. For the life of me I cant figure out why the shafts wont go back together, If i have the needle bearings in them like they came out, it stops a quarter inch short. If I take the needle bearings out, the tailshaft goes in fine. Its the weirdest thing
1low4x4
Nick
Pics
1low4x4
Nick
Got the seals in, stopped and bought a valve spring compression tool (I think I’ll take it back and make one out of an old wrench) and then I discovered a bent pushrod. So I’ll need to buy a set of those
Also, realized I put the intake on too soon, need to take it off so I’m sure all the PRs are in the lifters correctly until I get the springs back in
LeonT
