Vibration
Butcher
Indiana
Tom
C-10
Looking for some help here I've got a 1982 Chevy c-10 put 350 with 350 turbo in it. Have vibration while idling and while accelerating. Changed out tires and got balanced. Could not be driveshaft when not moving in park, checked belts and pulleys and fan. Clueless need help or ideas
dd1990
Ventura CA
Suburban 1500
check your flexplate, any ticking noise, seen cracked flex plates create a vibration
ali_c20
Austria
Alexander
C20, K5
Check balancer and torque converter.
BRetty
Los Angeles
Franklin
Agree about the balancer. Also check your motor mounts, they could be cracked or totally shot and you would feel vibration.
My gearhead buddy checked out my engine a month ago and revved it and said yeah, there is def. a vibration there. He suggested replace the harmonic Balancer, which is an $80-100 part and requires some serious pulley-pulling tools. "Wait! Are you saying that if my engine feels unbalanced, a part called a BALANCER might be the problem?" "Yeah." "No F***in WAY!"
ExtraZ
