WFO
Texas Panhandle
Removed the wire i had on temporarily to keep the throttle cable from slipping off and replaced it with the correct clip. Google said auto zone had them but it lied. Had to get them from Amazon.
You wouldn't happen to have a link to those clips would you?
I tried entering the numbers on your package, but that didn't work.
ChuckN
Bellinham, WA
Chad
@JamesSam I wouldn’t fret over Torx vs allen head. I’d use either. If you have to saw off for correct length, you could thread a nut on there before you cut it off, and then when you unthread the nut off the end, it’ll help clean up the threads if they need cleaning up.
Mine is still up on stands, waiting for the converter to come back. Apparently the guy before me had a converter in for a 200R4? Anyhow, that’s all I was told. Spent some time underneath cleaning up and trying to find an oil leak. I think I have a couple things going on, the oil center is probably leaking a little bit as well as the oil pan gasket around the main cap at the end. I thought initially it was the rear main seal, but it looks dry around the flywheel. Oh well, I’ll figure that out later. I got out the brake cleaner and cleaned everything up. Have some ARP bolts for the bellhousing when it goes back in.
Carb'ed Vortec 350
Changed the Earl, still got 40 Earl pressure at cold idle...
K5BEAST
