legopnuematic
Licensed Junk Dealer
MO
Spencer
Saw this on another forum and thought it may be of interest to some. Tomorrow 2/25 only Quick jack is having a 25% storewide sale.
Code: QJ25OFF
legopnuematic
MO
Spencer
Todays HF flash sale:
350 w/203
Picked one of those thread & size thingys the other day. On a wire, not a plate so it's easier to check everything out. Works purty well!
legopnuematic
MO
Spencer
I ordered a 3/4npt regulator filter for the airline project. Where I ordered it from has free shipping over $99, the regulator alone was below that, so browsed the clearance section and filled the cart up lol.
The 3/8 rubber line is temporary to feed the regulator, I’ll be going with all 3/4 ID to the compressor.
The pliers were from Menards, $6 for the small ones and $12 for the set of 10” and 12” everything else was from JBtool
Got a reverse bake bleeding tool. A new Arccapptain welder.
Interesting... i never heard of a reverse bleeder...
You put it at the caliper or wheel cylinder and pump brake build straight from the bottle up to the master cylinder where air wants to go.
codfish
Drive a hybrid. I NEED your gas!!
Newfoundland
gary
Ordered a plasma cutter from that jungle website. $175!
Works like a charm. I had to drill some holes in the inside auger fins on my old snowblower i have at the cabin, to make it throw snow farther. PITA with a drill. Used this and had 6 holes “drilled” in about 2 minutes.
Love it!!
It will see lots of use I’m positive.
Drauka99
Northwest Florida, USA
C-10
6.0 LQ4
Does a workshop count? They pour concrete tomorrow. 40’x60’. I’m setting 40’x48’ of it up as a workshop space. The rest is a full bathroom with the rest a hangout space with a small kitchen.
Have you tried the bleeder yet?
No... I'm nowhere near that yet. One of my buddies has this one, and it worked great on his truck. He used it to beed his complete brake system, and his hydraulic clutch.
One of the shops I used to work at,the service writer was sold on the Phoenix injector reverse bleeder. He had the shop buy one for shop use,we were hard heads I don't think anyone ever used it. Stupid because for free I could have found out if it was a worth while system,all the other knuckle heads and I stuck with what we new worked.
jfrchevyguy
