Looking for smog parts for 1977 gmc c25 w/454
jonbgood
east bay area , California
Johnny
I can not seem to find a Egr valve for this year and engine size. The ones I find look similar or exact but my year isn’t listed or says not compatible. Does anyone know of a comparable that will function properly? The original part number is
GM 17094028
Also need a diverter valve, anyone got one?
Thanks for any help locating these items.
Damn California smog emissions ‍
jonbgood
Johnny
fast 99
Spokane, Washington
Aftermarket valves sometimes are a consolidation of a few part numbers and may not flow exactly the same as the OEM number. Today have to use what is available.
To repair the vacuum port use a piece from another vacuum item. Cut or break it off a piece and glue to the broken valve. Use a tooth pick inside as a holder until glue partially sets. I have successfully done it with 24 hour JB weld. The fast set JB doesn't work as well. After glue sets add a little extra on the outside as reinforcement.
bbbbyffff6
