Tire damage
scenic760
SoCal
Suburban K10
Hey All,
Got a question for everyone..I just picked up a set of used Mickey Thompson tires and while I was stacking them away I saw this chunk loose on one of them...
Do I need to worry about this or throw some glue on it?
scenic760
SoCal
Suburban K10
I would have a real tire guy put a patch on the inside and glue the outside with that vulcanising glue they have. Also keep track of that tire and never use on a steering axle.
So a moderate amount of worry...makes sense! THANKS!
Carb'ed Vortec 350
I would toss it unless it will be used for nothing but speeds under 50.
Strick
Dunn, NC
Harold
C20 Crew
Keep it on the back. I've gotten dozens of damaged Humvee tires from Ft Bragg & have been fortunate that they were no real issues when running them. Some had to be patched (booted) & ran with a tube. Small price to pay when the tires retailed for $1600 & we could get all the blems we wanted for free.
HS
scenic760
SoCal
Suburban K10
I wasn’t too sure how it would affect the structural integrity of the the tire..
On one hand it’s the rubber outer layer protecting the belted portion so it shouldn’t be an issue..on the other hand it’s a small tear in the unit as a whole- kind of like a bridge with a small crack is detrimental..
A friend of mine’s dad was the lead trial attorney for Michelin and he could tell some stories..I wish I would have listened now, haha. He said tire blowouts in general are almost always from external sources or really old tires. He also said had never litigated a trial where the tire itself was defective and Michelin tires were hand down the best quality/safest tire you could buy.
Agreed on the date code. If it's a really new tire, I might try to find an old school tire shop that might have some of the vulcanization glue or whatever they call it and run it on the rear for a bit to see. If they're more than 4or 5 years old, I'd toss it.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Hey All,
Glue it. Don't worry till it's leaking. I've seen worse. Ods are it won't ever leak
Carb'ed Vortec 350
I guess I am way too cautious...lol...
Then again, when we go places, there typically isn't any accommodations, so having good tires is a must.
That said, glue it and run it
nvrenuf
Mobile, Al.
This ^^^
If you've ever worked in a tire store you've seen a lot worse drive away. Is it right? Not really. Is it junk? Not really.
Definitely glue or vulcanize that flap down to somewhat seal it. Moisture could get inside the layers and cause the steel belts to rust which would lead to separation problems (long term). I can't remember who but there is an off road oriented company that sells do-it-yourself cold vulcanizing kits, you may not find a tire shop that will vulcanize that area.
squaredeal91
Greg bush
1991 SB
Side story. In high school my friend actually used a red rag to fix sidewall leaks. On a 74 powerflaggon. Had super old tires on it with good tread developed some sidewall leaks. He used an awl to cram it in. Cut the ends off with a knife and all you could see was a few little pink flower looking things hahaha was so funny it actually worked.
scenic760
SoCal
Suburban K10
This ^^^
Appreciate all the replies!
That was my thought from the beginning, I have never worked in a tire shop but have seen worse on people's rigs. I think glue it, run it, watch it and keep it on the back is the way to go...I picked them up used so like Squareroot and a couple others said, the age of the tires are probably more concerning than the nicked rubber
Thumper350
