Black wire connected to indicator lamp
Dtrain
New Jersey
Dennis
Suburban R1500
350 cu in
Hi,
I have a 91 gmc suburban and am replacing the instrument bulbs with lleds. There is one black wire connected to a cluster gauge bulb socket, the other end has a small gauge plug style connector (almost like a jumper wire plug). Does anyone know where the wire plugs into? Could it be a warning signal wire from the body computer for the check engine lamp?
Any help would be appreciated.
Dtrain
YakkoWarner
Central Texas
Wolf
R2500 Suburban
If it is actuallly a black copper wire and not the optical lead mentioned above, good chance it is a ground (possibly for all the cluster bulbs?)
Dtrain
New Jersey
Dennis
Suburban R1500
350 cu in
Thanks,
I thought that’s might be what it is. The lights recently stopped working but not the check engine service light. I’ll do some tracking tomorrow and see where it could connect to. Thanks for the idea!
It may be the black cluster ground wire. On older trucks it was grounded to a post on the top of the emergency brake, but I think newer trucks have some type of ground bus up above the pedals. I assume that the ground bus has posts or spade terminals and the ground wire(s) go on them. However, I’ve never looked at the setup on the newer trucks.
Dtrain
New Jersey
Dennis
Suburban R1500
350 cu in
Thanks Bruce,
I will check on top of the pedals
Dtrain
New Jersey
Dennis
Suburban R1500
350 cu in
These are some pictures of the black wire and the type of plug on the end
Dtrain
Jgonick
West Texas
Joel
fiber optic -probably ash tray light
post of when I was trying to figure it out- post-LINK
attached is example and where it inserts to ash tray
Dtrain
New Jersey
Dennis
Suburban R1500
350 cu in
Thanks jgonick and calsgt
Yes that the exact cable I have.
SidewaystheSeven
