Gpaw44
- Apr 3, 2016
- Texas
- Alex
Brain storming to make the ignition modules last longer! While resurching this age old problem to the C-10s I came across this quote from a previous post and it got me to thinking.
"Ignition modules do have intermittent come and go faults. just keep in mind that these things need a full 12 volts supplied and a good ground to operate properly. They need the chassis ground path before the power is applied.Jun 26, 2015"
I also viewied a vedio where the person mentioned that the gasket that is between the base of the distrbuctor and the block could impeed the flow of current to a ground.
With this thought in mind, why not add an external ground wire to the top side of ignition module attached to the screw closest where the wire comes out of the distributor and take it to a ground.
Some of MSD modules come with a ground wire attached internally and you take it to a ground..
I would like to know if adding an external ground wire to my "NEW" I.M. will it damage it out before I try it. Any thoughts?
