Did this K20 come factory with catalytic converter?
Juke22
Salt Lake City
Jake
High Sierra
5.0L
Hello, I just bought a 1986 High Sierra 3/4 ton Camper Special 4x4.
I live in a state where emissions are required.
There's quite a lot of forum posts on the Internet that strictly state trucks with GVWR 8600 did NOT have catalytic converter in 1986.
However, the sticker under the hood is missing, and the emissions shop says my truck had cats in 1986, according to their book.
I've tried calling four different dealerships, and none could pull up my vin.. one of them told me this model truck had cats in 1986, based on his memory.
Someone shared this page, that shows the 5th character in my Vin is "K", meaning Light Duty Conventional 4x4.
Can anyone here give me a definitive answer? Thanks
The truck has a custom dual exhaust. I think the shop said I only need 1 cat.... Is that true, or would I need to get one for each pipe?
Options? Thanks
WebMonkey
Missouri Ozarks
my 85 k20 has the C6P option which, as you said, put it over the threshold for 'no cats'.
i don't know the specifics of the camper special though a non C6P k20, of that era, would have cats i expect.
i'm no expert or even a novice at what a truck needs to pass inspection in states that require factory emissions equipment.
good luck
'monkey
fast 99
Spokane, Washington
For 1980 through 1986, the same models as those for '79 used cats. However, a new C6P heavy duty option was offered for C/K 20/25 models which provided an 8,600 lb suspension package. These new, heavier 3/4 tons cleared the 8,500 lb limit,and so did not use converters during this time period, nor did C/K 30/35's.
For 1987 and beyond, all Chevy/GMC fuel injected engines used cats regardless of location or weight class. Only a few 30/35 series chassis cab models offered carbureted 292, 350and 454 engines, and those were the only models that did not use catalytic converters for 1987 on.
Note: The above applies only to U.S. vehicles. Canadian Chevy/ GMC trucks followed a much simpler story, I think. From what I have seen, no Canadian carbureted Chevy/ GMC C/K/R/V used cats, while all '87 and later fuel injected models did.
Keith Seymore
Motor City
Keith Seymore
4.3L
You have to determine your GVW.
Less than 8500 lb GVW - you need cats.
8600 lbs - no cats. And here is the documentation from GM (see page 39 of 188):
Link: https://www.gm.com/content/dam/comp...its/chevrolet-trucks/1986-Chevrolet-Truck.pdf
In fact - that is the entire reason the RPO C6P=8600lb gvw was created: to put it above the 8500lb rating requiring emissions equipment.
Do you have the SPID label?
K
Keith Seymore
Motor City
Keith Seymore
4.3L
fast 99
Spokane, Washington
GM Heritage shows no cats on all engines above 8600 GVW for 86 on page 39 both California and US. Couldn't link/paste the page.
With respect to light duty, until a vehicle reaches the 14-15k GVW all are considered "light duty". However, during that period emissions equipment in some cases was quite different between 8500 and 8600 GVW.
Juke22
Salt Lake City
Jake
High Sierra
5.0L
Thank you all for the fast response. I do not see any sticker in the engine bay, but I will post the ones from the door jam and glove box:
If I'm reading my sticker right, I think I got the C6P? Thanks
Do these stickers mean I have GVWR 8600 and C6P? Thank you
www.gm.com/content/dam/company/no_search/heritage-archive-docs/vehicle-information-kits/chevrolet-trucks/1986-Chevrolet-Truck.pdf[/URL]
K
I found the SPID, and I've posted the decals I found, i think i got 8600GVWR? It also says "California Emissions"?? Thanks.
Doesn't matter.
All square pickups, even one ton doolies with 11000 and 12000 lb gvws , are considered "Light Duty" pickups.
K
I think this is looking good for me, thanks for info.
Thanks for info, I think I might be in the clear with the 8600 GVWR? I think i found the page you mean, I see where it doesn't list "Oxidizing Reducing Converter" for HD emissions, and exempts C6P - I'll show that to the emissions shop. Thanks.
I also just noticed the sticker I posted says "California Emissions". Any idea what that means?
Great info, thanks all. This is my first truck, planning to fix it up, carry some dirtbikes and keep it forever.
I should add that the truck has a 305 put in it with custom exhaust. I don't think that should affect my original question, but I notice this engine was not put in HD trucks.
Keith Seymore
Motor City
Keith Seymore
4.3L
Yes - there was Federal Emissions, California emissions and High Altitude emissions (those were the choices). The content for each of those is explained in the packet.
You'll notice cats were not required for any of those over 8500 lb.
K
You need to find a more experienced emissions station, and one that will actually look up and show you the data instead of using words like “always”. Most younger (and older) guys have no real knowledge what specific emissions was installed on a nearly 40 year old truck, so having them rely on memory is not good.
The catalytic converter exemption GVW threshold changed over time, and the manufacturers changed with it. The original non-cat GVW was for trucks over about 6100 lbs, which spawned the heavy half Chevy and F150 Ford, and the GVW level for the exemption increased over the years.
Your truck is clearly one with 8600 GVW, and there should be no dispute. My Camper Special even has the GVW as part of the Camper Special emblem on the side of the cab. If an ‘86 truck at 8600 GVW did not require a catalytic converter, then the emissions guy is clearly wrong.
Auburn, Washington
Just talk to the emissions test place and bring em whatever info you have if they “think” it needed cats. Pretty cool exemption at the time. And apparently still beneficial in some states. Can’t believe you all have to test back to 1967. That’s crazy.
Be very quite about the engine not being original. Below I have posted all three pages of the EPA regulations regarding replacement engines. Read page 2 heavy duty vehicle section. Don't volunteer information,it may condemn you,don't nit pick,they can nit pick worse.
Carb'ed Vortec 350
Auburn, Washington
Agreed. And with the 5.0 transplant it likely doesn’t look totally OE under the hood (air cleaner etc). But to the OP, the engine itself physically looks the same or very similar so that’s a plus.
If you search this site and any hotrodders site you will find many folks who are trying to figure out if they just bought a 305 or 350 SBC. Unless the inspector is willing to crawl into the back of the engine and inspect the pad with the engine casting number, there is nobody I know who could tell a Gen I 350 from a 305.
If all the 350 accessories and parts were moved to the 305 there is no telltale that will distinguish 305 from a 350 by just looking into the engine compartment. This includes moving components like the alternator, water pump, air cleaner, A/C compressor, exhaust manifolds, etc., since all the external parts from the 350 will fit on the 305.
I also find it really weird that the OP's truck had a 350, but they swapped in a 305. That is really unusual unless the 350 blew up and the 305 was the only engine available cheap at the junkyard. There is no GM crate 305, but there were thousands of GM Crate 350's sold over the years.
cahillasher76
