Towing with my 86.... hints, tips, essentials?
kapitein
Netherlands
Alex
C20 Suburban
Hi all,
For the first time I will be towing with my 86 C20 454 TH400.
The truck is in really good shape mechanically, but im wondering if there are any words of wisdom when towing a camper with these rigs?
When fully loaded the camper is right around 5500lbs.
Extra coolers neccessary for the TH400 for example?
Would love to hear experiences, I attached a picture of my camper below :)
1st priority - electric trailer brakes and a good controller. When you hit the brakes you want that trailer to drag you down like an anchor, not push the back of the truck into a jackknife. It weighs about the same as your truck, so it will definitely push the truck around.
Also verify the balance of your trailer, with the goal that more weight is forward of the axle, and about 10% of the weight is on the hitch. You never want the weight to be too far behind the axle, since it will tend to see-saw because the rear goes down and tries to lift the hitch off the truck.
The main modification I would recommend is a good external transmission cooler, and maybe also a trans temp gauge. The best coolers to use are the stacked plate coolers like those from Tru-Cool. I would use the largest one you can fit in front of the radiator, plumbed in series with the trans cooler in the radiator. Many of their coolers also have a temperature-sensitive bypass so that they allow the transmission to warm up properly in cold weather.
kapitein
Netherlands
Alex
C20 Suburban
Thanks,
Electronic trailer brakes arent a thing here - we use an overrun braking system and this camper has something called an ALKO hitch and chassis with an anti-sway device. Its all on Google if your interest peaks you.
BTW, do you happen to know the max. safe nose weight for a Squarebody.
I had a Tru-Cool 40k on my previous 07 Burb - so I think I will invest in one of those again :)
Thanks,
ALKO parts have been difficult to get here for a while now, and expensive too. They were bought out by Dexter (I'm guessing just the U.S. market?) and most stuff has been getting discontinued.
Anywho, 5500lbs is really not a heavy load for the typical 3/4 ton truck. Yeah it's a bit large of a trailer, but at lower speeds it doesn't really make that much of a difference unless it's a very breezy day. The most important thing since the trailer brakes are covered already, is tires. You want a good, strong tire with a higher load rating for the truck. A cheap tire or a lower rated tire can cause a lot of squirm and sway. If spending a lot of time at higher speeds, an aux trans cooler and a temp gauge are certainly not a bad idea.
fast 99
Spokane, Washington
Agree with above, tranny can't be too cool when towing. Although might be excessive I have 2 coolers in series after the radiator cooler with a temp gauge. On a warm [not hot] day will exceed 200 degrees pulling a moderate grade. This is a tow truck. Total weight in tow is about the same as yours 10-11k.
Auburn, Washington
That trailer just looks like it needs anti sway. Although they must’ve put all the heavy stuff forward based on where the axles are.
Trans cooler, trailer brakes and let er rip.
Truck suspension and drivetrain are sufficient for that trailer.
Tonimus
Phoenix
Tony
C10 Suburban
My Camaro on a car trailer weighs over 5k pounds. I pull it with a C10 Suburban with 3/4 ton running gear and a 454 with TH400. I do have an external trans cooler. I had no real issues. Pulled a little over 300 miles round trip. And it gets HOT out here.
Auburn, Washington
You have surge brakes, correct? That’s how most euro light trailer are?
Idk how much towing experience with surge brakes you have but be aware of downhill towing and surge brakes. Easy to overheat them on long downgrades.
Auburn, Washington
Good point although even if that TT is only 5500 it’ll tow heavier than a car on a flatbed. Plus I bet that TT is over 5500 loaded ready to camp unless it’s aluminum frame and really lightweight construction.
Tonimus
Phoenix
Tony
C10 Suburban
Per the specs on the camper, 5500 pounds is max loaded weight. Specs say 4200 pounds wet, no cargo. Yeah, it'll tow different for sure. But the car on the trailer was tongue heavy, which makes for its own challenges. Properly loaded, I think it'd pull fine, especially at the speed limits in the Netherlands.
Auburn, Washington
Agree, the size of the truck in general will handle the trailer “ok”.
That said, that camper will “feel” much bigger than a Camaro on a Uhaul trailer even if they’re roughly the same overall weight. Tail wagging the dog especially with the long rear overhang and centered axles. And variations in tongue weight over bumps n dips in the road.
Back to the OP, the other question was what’s the max or safe tongue weight? OP hasn’t said what the tongue weight is on that trailer but based on the looks of it, the fact that it’s probably designed for a “large” euro suv to tow and it comes with anti sway installed (due to light tongue weight), tongue weight is least likely to be an issue or limiting factor.
But that’s largely a function of the hitch receiver on his truck. He will have plenty of suspension and axle capacity, especially with weight distribution, provided he’s not hauling a lot of weight in the truck bed. Assuming it’s a class IV receiver it’s fine. Those are typically 1000/10000 lb rated.
Honestly it’s more about the condition of the truck. Lots of variables in a classic vehicle.
I don't know, I've got a 30ft travel trailer and it pulls just as nice behind my Suburban as it does my 5000lb deckover trailer.
kapitein
Netherlands
Alex
C20 Suburban
European campers are just built differently. Full aluminium chassis and lightweight walls etc. At 4200lb dry, this is about as heavy as a Euro camper gets. 5500lb wet is, again, about the max you will ever see for a euro camper.
Every euro car has a max tongue weight, and they are (in general) surprisingly low - the average being something around 140-160lbs.
The trick with Eurocampers is to load as much weight as possible on the front, without exceeding the tongue weight. Too much weight out back can lead to some real interesting moments on the highway. Max. highway speed limit with a camper is usually 60mph.
Ive done plenty of towing and got my commercial licence... I just never towed with a Squarebody before :)
Auburn, Washington
To each their own I suppose. Like you, I’ve towed a lot of different trailers, from AZ to AK and WA to WI and I’d take an equal weight flatbed with a short (height) load over most any travel trailer or even enclosed cargo trailer (albeit better than a TT usually) about 11 times out of 10.
Wind resistance of a flat nose high profile trailer is much worse than a trailer with no nose.
Tail wagging the dog is more perceptible in most cases.
Cross winds. Yup flatbed ftw here.
Vertical center of gravity. Another + for the flatbed.
That’s like saying a 4000lb truck camper hauls the same as a 4000lb pallet of bricks in the back of a pickup truck. They’re completely different.
It was super obvious to me once we got a truck camper about 10 years ago.
Towing the boat, prior to the TC, got x.x mpg.
Hauling just the TC, got about the same mileage. Doubling up the Tc and boat behind, mileage didn’t go down appreciably. And the boat anchor on the hitch actually decreased body roll a little bit with the camper. In essence, the wind resistance of the TC and higher CoG of the load from the camper basically erased the boat from the equation as to how hard the truck was working.
Alas I’m getting off topic.
Yes a big block C20 in good running order will tow that camper alright.
Although the lack of tongue weight (I understand why, most euro tow rigs are German or British suvs which are far better suited to hauling kids, groceries and ass than they are hauling a camper like that that “should” have 600-800lbs tongue weight to help with stability.
I tow my family travel trailer a few times a year with my square. For family trips I use my newer suburban with a 6.2/6l80 and a tru-cool 40k. When I’m hunting or camping solo I will take the square. Weight is almost identical to your except with a load leveling hitch and electric brakes on both axles. The square is a 1980 K25 with 350/TH400/NP205 and a stock 97 K2500 trans cooler after the radiator. It will happily pull the trailer on highways at 60mph plus for extended periods of time and up/down the coastal mountain range and Cascades.
1985Silverado
