78C10BigTen
pennsylvannia
C10 BIG TEN
Maybe @78C10BigTen Ted, would know what the old cats are worth?
Cats depend on the age and the vehicle it came off of as to what make up of materials they have in them. Those ol bead blowers usually arent worth much. We have a system that we put the manufacturers numbers off the cat in and it tells us the current market value based on the specific number. Our state also requires a title or registration to the car wich it was removed also. Due to the high theft rate.
Auburn, Washington
Ok I am now guessing the TBI would have trouble with no catalytic converter being in there?
I was actually getting somewhat excited to have a solution to this so easily...but I have not thought about the complications of a TBI set up versus a just carbeurated set up. I imagine the straight pipe solution would be no problem on a carbeurated set up-pre 1987...
You’re not getting it cut with a tubing cutter. No room to spin the cutter around it.
If you actually want to remove and save it, keep chopping u bolts at exhaust mounts until you can get the exhaust system to slide backwards a bit. Then do like the last person did, pry up the already hacked slots in the fat pipe and pull, wiggle, pry, hammer it off in one piece. Then you can jimmy rig it back on.
Back to it, truck will run fine without it. Maybe better. It’s a dumb system with no downstream O2. Actually first year of cats on >8500lb trucks iirc.
If it’s original then it’s quite likely not in the best shape for flow. But icbw.
It has been removed at least once before and really doesn’t look “factory” to me other than it looks like old factory style pellet cats but I’m taking @bucket word for it.
PS you don’t have to take the tank brackets off nor the exhaust if you raise/remove the bed.
At this point it may have been easier to do that. And still could if you don’t want to hack the exhaust.
Although I’ll admit at this point I’m getting a bit confused now what you’re trying to fix. And why.
Regarding what to get to straight pipe it. Also variable depending on the condition of and how the rest of the exhaust is mounted.
If it’s sturdy and won’t move on either of the cat (with it removed) then 2 wide band clamps and a piece of pipe is the easiest although $20-30 more than using u bolt clamps. If you use u bolts or the exhaust needs the support of a rigid connection where the cat is, then you need to reinstall bell n spigot on one or both ends for strength.
This is also the reason I say take the bed off. It’s no harder really than messing with everything else and it makes all the tank work much easier and more accessible. Just replace everything once that is old and/or suspect at once and nothing else to wrestle around (except the bed off course but that takes 1 minute to remove or replace with 4 men.
Strick
Dunn, NC
Harold
C20 Crew
Trying to get the big girl some new hue! I'm past ready to drive this '87! AND yes, I'm still using my $10 Hobo Fright gun!!!
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
You make great points here Todd.
I can remind you of my truck symptoms but I'm sure it's driving everyone else crazy. Currently I am going after the drivers tank since it hasn't worked in over a year and it needs to be replaced. I then realized the cat is in the way. I feel like removing the bed would be a little too much for me having to work in the drive way. Although that may not have been the case at this point as you ha e observed. If/when I can get the drivers tank and fuel pump, cat(or no cat) replaced I am hoping the shuddering under throttle will have been remedied and I can then begin troubleshooting on passenger side tank. If none of it helps the studder then I can begin at square one again with a new drivers tank and cat with only the old passenger side tank and fuel pump to replace.
So, long story long again initial studdering has led me to start a longer term goal of replacing tanks and sending units. No official diagnosis I just believe it is fuel system or cat related. Also if I had tried to drive it in to a garage the wife would have cut my b***s off. I also was very overwhelmed looking at how much the PO paid in labor costs to just replace the fuel pumps in each tank.
Strick
Dunn, NC
Harold
C20 Crew
That looks fantastic! Reminds me of my ole '76 High Sierra.
Ajax19
Socal
Ajax
Just grab the saws all and you can get some pipe and clamps you need at the parts store for reinstall
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Sorry All,
I will only post in this thread when I make some progress and stop derailing it.
This is the longest my truck has been OOC since I have owned it and I don't like it. Until this problem I have been able to fix the problems or upgrade if needed.
Thanks all for your input I appreciate it.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Brought home a new tank and sending unit and put it in the bed for storage.
78C10BigTen
pennsylvannia
C10 BIG TEN
A lil newer but my 94 gmt400 burban had a tbi and no cat and ran just fine...
EDIT: for almost 360k miles lol
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Took the bumper to work today and used some Oxy-Ace to reform the top edge, just a side project within a side side project - Hey Look! Its a squirrel!!
Redfish
Prairieville, LA
Andrew
V1500
Sorry All,
The only thing you need to apologize for is for letting your wife decide whether or not you can use your garage to work on your truck. This thread is a perfect place to get help and advice from this forum.
I personally would not let a woman decide what I could and could not do at the house I pay for each month. Unless of course she was smoking hot, could cook like Rachael Ray and treated me like visiting royalty every day.
I would continue dispensing my valuable words of wisdom but I have to go. The charcoal is almost burned white and I have to grill the burgers for our supper. You know what they say, Happy Wife Happy Life.
But nothing rhymes with Husband...
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
No if I were to take the truck to a mechanic at a garage to work on it is what I meant but I get what your saying, which is why I am running around buying all the stuff I need to do the next project for the truck without asking permission. I will be asking forgiveness. Oh, and I cook dinner too. Lol.
I really hope you will replace the pump too, and not with the cheapest one they offer. I do believe the pump is your problem, but without a pressure test, it's just an educated guess.
zapattack
