Need help wiring power windows and door locks 83 K1500
83gmck1500
Peter
K1500
383 Stroker
Let me start by saying my son and I are rookies at this. We are taking on completely rebuilding a 1983 GMC k1500. We have purchased a complete (sorta) wiring harness from American Autowire. It does not include wiring for the power windows or door locks but does indicate it includes a switched 12 volt to use for this application. We need help wiring it all up. We have the double switch for the drivers side and single switch for the passenger side along with the motor pigtail for each side. the motor pigtail has a blue and a dark greyish wire. Which wires on the switches do these connect to? And then what do the remaining wires connect to.
I have tries to attach a picture of the switches and pigtails but it keeps telling me the file is too large.
anyway the wires on the dual switch are black, pink, black w/blue stripe, blue, brown and blue w/white stripe. Single switch is has pink, black w/ blue stripe, tan, blue and blue w/white stripe.
Also, how do the power door locks get wired up?
Thank yall in advance for your help
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
GM used a screwed up complicated power door lock system in those years. It’s hard to explain, but pushing a button on one side uses the other side to complete the signal path to the relay. Entirely to many wires, too many failure points.
My fix: use a common door lock relay from a later truck/van, and wire it using the later wiring diagram. Since you are starting from scratch, that’s the easiest solution. The later relays switch polarity internally, you use only 3 of the 5 button on each door switch.
I used this method on my 81 GMC, and my son’s 92 Yukon. The door lock relay is cheap if you buy it new, but your nearest junkyard will be filled with them. Lots of GM cars used the relay, make sure you get the matching connector.
This is the relay your looking for, and here is a wiring diagram.
Auburn, Washington
@Matt69olds, the sheer level of knowledge and ingenuity here just blows me away sometimes. Thank you for sharing.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
It helps being cheap! I grew up watching Scotty on Star Trek (the Miracle Worker!) and McGuyver. It ain’t broke if they can fix it!
It’s been very beneficial to have access to a couple salvage yards that allow me to roam around looking at cars. I have found it’s sometimes easier to adapt what’s already out there to serve my needs instead of engineering my own fix.
I have been fortunate to work with some VERY talented and knowledgeable people over the years. I consider myself lucky, what I can’t do on my own, someone who can is usually a phone call away!
350 w/203
83gmck1500
Peter
K1500
383 Stroker
Thank yo for the advise sir.
Camar068
10 yrs Air Force
I got a door to dash to door harness from someone on here. It was great until things slowed down. I added the LMC relay kit and it helped a bit.
not having AC installed was my concern. I was worried I'd be driving home in high heat an not be able to roll the window down. Me out being out of shape, I'd bust a window out if I had to after a trip or 2. I converted back to manual.
If I still have the harness and hardware (including new regulators and switches w/the relays)....you can have them. I'm SE KY 3 miles from I75. Send PM if you want it. Splicing/soldering WILL be required. I don't care to show you how to solder if needed (10 minutes max).
83gmck1500
Peter
K1500
383 Stroker
83gmck1500
Peter
K1500
383 Stroker
thank you sir. I sent yout a message
bluejag350
lexington, ky
Charley
C 10
What years newer should the relay be to look for?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
If your referring to the relay I suggested, just about any GM car or truck 1990ish and newer will have one. Sometimes they are in the door jamb area, behind the glove box, it shouldn’t be hard to find one.
nclasen
Nick
5.3 LT
Working on a similar project wiring an 87 K10 from scratch and I would like to make the power windows and locks up to date. I do not have any of the original factory wiring so I am at a loss when determining how it was done originally. To start I bought all new switches for the locks/windows with matching pigtails. Also purchased the LMC HD PW kit with new motors. I’m starting with the PW’s and I could use some direction on how to map some of the wires. LMC instructions are great but I am uncertain of the connections for the BluWhi and BlkBlu wires on each switch. I want to assume that they are directly mapped to the same on the passenger sw? Also Blk on the master switch is a ground to the door shell I presume?
Lots of knowledge on this board so thanks in advance for any help given.
GorillaHumper
