Lowered jimmy
jimmy78
bc
matt
jimmy
5.7l
Lowered my 78 jimmy rwd with a bell tech 4/6
Back end dropped 8” since I didn’t re arch the leafs. From is dropped 6” with drop spindle and 3” lowering spring from brothers truck.
Removed the inner fenders to make sure there was no rubbing issues ( building new inner fenders for replace)
Only down side is the front coils pop out of top mount when the suspension is drooped. Considering limiting straps to stop this from happening.
Did you try finding shocks with a shorter stroke to keep that from happening?
@Mr Clean lookie
Just FYI, you very well may not be able to get it aligned with those 3" drop springs and stock control arms. I have 2.5" spindles and trimmed my stock springs a little at time until I was happy, I ended up being roughly 5-5.5" up front and cannot get the camber perfect. I got about 25k miles out of the first set of front tires that way.
@TotalyHucked is correct. When you drop that much it is best to go with tubular A arms. Unless you want to buy tires all of the time, or you won't be driving it much. I have CPP coil over kit on my 2WD Blazer. The quality is nice, customer service not so much. I wish I would have went with QA1. Need some better pics of the Blazer. :waytogo:
zulander
Indiana
Edward
c30
Yes, more PICS!! Love a slammed Jimmy
Did you look at moog problem solver k6184 offset control arm shafts?
bluex
Spartanburg SC
C15
This
With these I had no trouble getting mine aligned even on bags. Except for wanting the ride height to be tucking wheel which got in the way of sensor mounting lol
Fat 454
Australia
C20 Suburban
pics , pics - its all in the stance - need a good one from the side please. Always looking for real world experience with drop kits - what motor are you running ( weight ) - seat in the back etc. etc?
slosh tubz for the front ?? - are they still around ?
Yes they are. About to order a shaved firewall kit for my 2wd Blazer.
tobiahr
Atascocita, Tx
Tobiah
Blazer 2wd
L59 5.3 swap
What did you do about the rear crossmember. Mine is kissing the driveshaft when I compress the rear.
Hog Hunter
