250i6 mods for Highway Driving
Tdwmaxwell
Athens GA
Tyler
At the moment I drive a 1982 C10 with the 250i6 and the SM465 transmission, don't know what rear end. I'm looking to make it a bit more comfortable as a highway cruiser. I've been doing more highway driving recently and it feels like I put a lot of strain on the engine (I don't currently have a tachometer so I have almost no idea what my RPMs are). I've been thinking about doing an engine swap to a V8 but was wondering if I should try changing the gearing first. Any recommendations about what I should try to make highways more comfortable?
Auburn, Washington
If it’s an original 6cyl I’d be surprised if it has steep gears. But if that’s what you’re referring to, a V8 won’t help high rpm’s.
If your issue is just it doesn’t have enough power then more power is the solution.
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Are you happy with the original engine and want too keep it? If yes I would install a tachometer (I prefer to have a tach in all of my cars) and check the rear end ratio. Tire size is also related to engine rpm.
You can use a Engine rpm calculator to get the rpm for current setup and the effects of the changes you want to make. No need for a tach then.
With that data I would see what needs to be done to achieve the desired goal.
This one has a list of popular transmission gear ratios:
https://www.crawlpedia.com/rpm_gear_calculator.htm
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Look in the glovebox and take a pic of the sticker and upload it. We can figure out your axle ratio from the SPID....
Or, compare for yourself.
I believe it'll be a GUx code, like for example, GU6 is 3.42, and GU4 is 3.08.
Assuming its the original rear gears, we can go from there and reccomend a change that'd suit you
mcarlo86
ND
Suburban
Up in this part of the world, if a C10 came with a SM465 4 speed and a 6 cylinder, it usually had 3.73's. That being said, check your SPID label if it is still there. If it had a 3 speed manual or automatic, then they often had higher gears like 3.08 or 3.42. My dad has a '76 C10 with the 250, 465 transmission and 3.73's with 235/75R15 tires. It cruises nicely at 60-65 mph and will run 70 fairly easily, but probably wouldn't be my choice for interstate/freeway driving. If you do have 3.73's, then finding an overdrive transmission would help a lot. That all being said, a 250 will handle 3,000 rpms just fine and it really isn't adding "strain" to the engine. They handle rpms better than a 292 does.
Carb'ed Vortec 350
3.73 is a fine gear for an I6 engine. On my Jeep Cherokee with the 4.0, I went from 3.54 to 3.73 to run a larger tire, but I did the math to keep roughly the same rpms down the highway. Granted it has an OD transmission, but there are times where I don't even use the OD. 3,000 is 70mph in 3rd. 2,200 is 70 in OD. 3,000 is just fine, but I do understand you wanting a lower rpm if possible.
There are upgrades you can get for the 250 that will improve to engine's output. https://www.12bolt.com/
Carb'ed Vortec 350
The rpms stated in my previous post are with 29.5 inch diameter tires
77Dmax
vt
Joe
Step one is figuring out your gears and see where you're at.
Welcome from just south of you in Winder/Auburn!
I would start by jacking up the rear, make a mark on the driveshaft and then spin a wheel. Count how many times the shaft spins for 1 rotation of the wheel, 3 3/4 = 3.73, a little more than 4 = 4.10, etc, a little less than 3.5 = 3.42s. I'd venture to guess you've got 3.73s, that's what our '76 shop truck has.
2nd thing I'd do is get a tach. That way you can truly see where you are for highway RPMs and then make a plan to adjust. If you don't tow/haul heavy, you could put in a taller gear but if you do haul/tow, I'd leave it alone. Our '76 250ci 6cyl and 3 on the tree truck will cruise at 70-75 but she's buzzing, 60-65 is her sweet spot
MikeB
My very basic 82 C10 SWB with a 250-six and 3-speed manual trans came with a 2.73 axle ratio. The standard FR78-15 tires were 27.6" tall.
I eventually went the 350/TH350 route which worked fine with the 2.73 and 29.5" tires. But had I kept the 250-six, I think 3.08 or 3.23 would have been a good combo between around town and highway. That's assuming an engine in good shape.
Lots of info on your 82 C10: https://www.gm.com/content/dam/company/no_search/heritage-archive-docs/vehicle-information-kits/chevrolet-trucks/1982-Chevrolet-Truck.pdf
Check out page 10 for C10 power teams (non-California).
erikm00
