New to engine swaps, looking for help with an LS3 swap into my 79 k20
cduneman
Montana
Chase
400 SBC
Hello, I have a bone stock 79 k20 pickup, and it has a 400 sbc and a turbo 400 transmission in it right now. I have a screaming deal for a complete LS3, and am planning to swap the LS for my small block. For now I want to keep the turbo 400, but possibly switch it out down the line. I am looking for help coming up with a parts list for all the things I will need to swap, and what kinds of work I have to look forward too. Thanks, any suggestions appreciated.
Hunter79764
Grand Prairie, TX
Suburban V20
There's tons of info out there, but in general, you need to address a few items. From the fact that you are asking the question, I'm going to steer you towards the "Easy button" approach, not the hardcore budget build:
Fuel system - Likely the best way is to essentially get the fuel system from an '87 TBI truck, but with a higher pressure pump. New tank, run lines as appropriate for your skill/budget/existing condition level, and make sure you have the appropriate regulator, probably a "returnless" system on the LS3 that can use a QUALITY "Corvette" filter/regulator, or get standalone aftermarket filters and regulator, then get it all connected together.
Wiring - Buy a harness from a reputable vendor, or do your homework on how to cut/splice/modify one you already have. I'd suggest getting a factory PCM with it if you don't have one. The Holley stuff seems Sexy, but my opinion is that factory is better for 90% of swaps out there, but get your harness/tune/computer if needed from a good, reputable source.
Mounts - I'd say you have 2 options - Leave your transmission in place and buy a set of adjustable/slider mounts from someone like ICT or Dirty Dingo and run no AC or a high mount/aftermarket AC, or get the Tejas mounts, use the factory AC compressor, and use the chance to upgrade your driveshafts as your transmission will move forward a few inches.
Alternatively, you would possibly be able to leave your transfer case in place, but swap your TH400 for a 4L80e with the Tejas mounts. Read up on Tejas's site or call them, he's a good guy with lots of info.
AC - See above, either run the factory LS3 compressor, or get a Sanden of the appropriate style. The old compressors from our trucks are not that great, and the hoses need to be replaced anyway.
Transmission - If you keep the TH400, get a spacer to go between the flexplate and the torque converter. There is a 6-bolt spacer, or just a little stepped donut. Either one should be fine. You may need to "adjust" some flexplate holes to line up, the old ones are on an SAE circle and the new ones are Metric, so the holes may be a hair off. A die grinder can fix it easily, or any number of folks will happily take your money and send you a new plate with plenty of holes in it.
Gauges - Keeping your TH400 simplifies the speedometer, but your tuner may need a VSS. Going 4L80e might help that situation if you do it right, and keep your speedo cable on the T-case, or you may do a 4L80 with the right T case to keep passenger side drop and get a VSS, but need a digital speedometer. Your tuner may have more info, and/or do some digging about using a 2WD 4L80e for the VSS in the case. Other gauges can generally be done with the factory sender on an adapter to mate to the LS engine. Info is out there, and it depends on what exactly you have or need. And of course, a full digital dash is always an option if you want that.
Hope that gets you going!
cduneman
Montana
Chase
400 SBC
That helps a bunch man thank you
Chepe
Tennessee
Chepe
I put a junkyard 5.3/4L60e into my '83 K10. Bolted a reluctor ring onto the output shaft where it goes through the 4WD adapter, in between the trans and the t-case. Drilled a hole for the speed sensor and sent that signal to the ECU, which is also running my transmission. Speedometer cable still running from the t-case as stock. Used the factory harness, cut and spliced, does require some time and is dirty work but it was cheap and it works great. I bought HPTuners and unlocked the ECU with that. Have made some adjustments with it since. I used ICT mounts - Tejas makes great stuff and the people there are super helpful, but I thought one A/C system would be easier to rebuild than two new driveshafts. ICT bracket for sanden compressor, got two hoses made locally, found the right size belt, works great. The new engine has made my old square a lot of fun. Your LS3 will be that much better.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
What is a LS going to do for you that the 400 can't do? People swap 350's and collect 400"s I heard that once here. I've had a few 400's and am sold on the torque that they produce.
chevelless07
