LMC AC controller has too many detents
Chris64
San Diego
I ordered the AC/heater controller to replace the one I have (which is missing knobs, scratched and just looks awful).
The problem is it has too many detents for the top lever. The label is correct, it has 6 sections, but 7 detents.
I'll try to get fancy with fonts to explain - When I slide the knob it snaps on too many places:
Stock
OFF A/C VENT HEATER BI-LEVEL DEF
X X X X X X
LMC Controller
X X X X X X X
So that's weird, right? I'm not sure if this is going to work properly. I can just aim for the middle and ignore the detent, or I can probably use parts from this to make the factory one look new again. I'm just wondering if this is a defect or maybe not a big deal. I could even possibly modify it to have the proper detents.
On a side note: I always hated this control mechanism. Even in the 80's. Japanese cars AC controllers have always made way more sense to me. What if I want the recycle on/off with floor vent with heater on with AC on? Just because! :33:
ali_c20
Austria
Alexander
C20, K5
I have an original AC controller in my 79 K5 and I think there is a detent between vent and heat. Not 100% sure, I will check and report.
legopnuematic
Licensed Junk Dealer
MO
Spencer
1973-1975 HVAC control:
1976-77
Later is similar to 76-77 but minor changes.
1lejohn
texas
john
k-1500, 2500 HD
I think the bottom one is for a later model truck. 80's version. It matters on the vacuum switch where all the lines come in that run to the plenum doors.
Chris64
San Diego
This is what I have
So six positions. The stock one for sure only detents on those 6 positions. The LMC just has this exact same graphic, but with 7 detents.
Jgonick
West Texas
Joel
Surely they didn’t put the graphic (front) on a wrong switch- but I guess anything is possible.
My suggestion is to call LMC and ask. I’ve had to call them in the past to clarify a description on a certain part. They were very helpful when I called.
Chris64
San Diego
You know - I didn't even consider this because most online places don't give any service. I called them and they were very helpful. They wanted pics so they could forward them to the right people and if it's wrong they'll replace it.
I'll keep this thread updated with the outcome but bravo LMC for having humans to help.:cheers:
The dash controller has to match the large vacuum switch bolted on the back (it’s visible in the photo of the newer switch). You cannot mix and match years.
Also, my original ‘75 controls do not have the extra detent you show in your diagram.
The ‘75 switch has no Max position because recirculate is controlled by the Temp slider. There is a temperature slider detent just short of full cold, and that is normal mode. Then you push the temp slider all the way to the left and it hits the Max/recirculate detent and you will see the kick panel recirculate vent open up.
My recirculate mode is a little slow to kick in, like it doesn’t quite apply enough vacuum to the recirculate pod, but it does slowly move after about 20-30 seconds.
Chris64
San Diego
The dash controller has to march the large vacuum switch bolted on the back (it’s visible in the photo of the newer switch). You cannot mix and match years.
That's good info - thank you. I was wondering about that left detent on the cold. Now I know.
85 red GMC
SW Florida
Bradley
K1500
1976-77
I was thinking bi-level which came along later in the offerings. If you don't have the right vacuum set up for the connection, I would think the extra space would cause problems with vacuum distribution. Can they send you one for the right vehicle you have and take this one back?
85 red GMC
SW Florida
Bradley
K1500
My 1985 has the bi-level I believe.
I have not found a source for the vacuum connector attached to the back of the dash switch. Several sources sell the switches, but they do not come with a new vacuum connector.
The vacuum connectors have a parts number stamped on them, but I have not found a reference to explain them.
Chris64
San Diego
Well LMC did follow up with me but not with the news I wanted to hear. They said that this part is correct and nobody's complained about it before "so it should work fine."
I think it will work if I straddle the detents and just eyeball it, but it still seems rigged. I may just use this to tune-up and beautify the original.
Camar068
10 yrs Air Force
If your not happy, 6 on the label and 7 detents.....send it back. You didn't get what you paid for. Having to put it in between is something you do on a part thats 20 years and older and needs to be replaced lol.
Just my thoughts lol.
c10build
