Hi - from Upstate, SC
redRock14
Upstate SC
Joe
Silverado C10
350-TPI
Here is the 85 Silverado C10 I recently acquired. It has an L98 TPI and a 700R transmission, even has AC. Everything is working except for the HVAC vent control. I need to trace the vacuum lines and find where the leak is.
First thing I did was order a power window relay kit. The windows go up and down no problem at all; the power locks work perfect too.
Paint is okay - no rust. Has a sliding back window. The weatherstipping is missing though. Engine needs some detailing but overall it runs well. Put some new tires on the original factory wheels with beauty rims. Pretty happy with it so far.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
animal
Lee
c10 silverado
350ish
:welcome:
Soundmound
North Central Washington
Dave
Scottsdale
Welcome! My leak was behind the controls. There's a rubber "manifold" that internally fell apart and wouldn't align the doors properly. Was a right pain to track one down for replacement.
redRock14
Upstate SC
Joe
Silverado C10
350-TPI
Thank you Soundmound. I need to check the hose going through the firewall first. I would not be surprised if mine ends up being like your situation though. Thanks!
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Welcome from VA. I was born in Greenville. I grew up in Taylors. Abruptly moved to PI when my Dad got a job in Georgetown. I miss the old SC. Nice truck.
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Nice truck.
WFO
Texas Panhandle
redRock14
Upstate SC
Joe
Silverado C10
350-TPI
Thanks everyone for the warm welcome.
@TotalyHucked - I found your build thread. You have a very nice truck!
The L98 in my truck is from a 92 IROC. The intake runners are different, this is vintage stuff but back in the day the "siamesed" intake runners (as fitted) were the rage. So, that is why the intake looks different. The original intake had the individual tube runners.
The engine bay needs cleaning up - it has been sitting for quite some time. Here is what the interior looks like. The dash is in good shape, currently with a dash cover. The bench seat is all original; not sure about the current cover but hey, it is saving the seat. Gauges all work however, the speedo is off by about 5 mph.
I really want to get a lowering kit. However, I am not too keen on cutting the frame. I have not done my research on this yet, but surely there is a kit available that can lower the truck a little without having to cut the frame. I also want to keep the original wheels so this might not be possible.
@bluex thanks for chiming in! I live not far from you, in Greer. I actually saw a white Squarebody similar to mine in Greer the other day that had been seriously lowered with aftermarket wheels - it looked awesome!
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Grrrr
Chavez_78
