Instrument cluster swap from Idiot lights to full gauges K5 K10 K20 K30 C10 C20 C30
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Here's a quick write up while this is still fresh in my mind. I picked up a 1986 K5 Blazer Custom Deluxe that had the basic cluster with only Speedometer, Large Fuel Gauge and 4 idiot lights for Battery, Oil, Temperature, Brake. I picked up another cluster at the junkyard. It was a 80s gauge cluster with 85mph speedo, and gauges for Battery Voltage, Oil Pressure, Engine Temperature.
Replace coolant and oil pressure switches with sensors.
If your truck orignally came with Idiot lights, you need to replace the coolant temp sensor on the side of the block with whatever rockauto or your favorite parts source says is needed for Gauge. I used SMP TS76. Connect your original temp wire to the new temp sensor.
You also need to replace the oil pressure switch on the back of the intake by the distibutor with an oil pressure sensor for gauge. I used SMP PS154. I had to use a 1" 1/16 shallow socket to get the old oil pressure switch out of the back of the engine block. Unfortunately the new oil pressure sensor won't just thread in because it is too large and hits the back of the intake. I'll have to go to the local hardware store and look for a 1/8" NPT male to 1/8" NPT female 45 degree fitting so I can angle the Oil pressure sensor away from the intake and distributor. If anyone knows the part number for this fitting let me know.
Something like this should work
After disconnecting the oil pressure switch, I noticed my choke no longer opened when key was on, checked voltage at electric choke and nothing. Turns out the oil pressure switch is needed to provide power to the choke. I just made a jumper wire and connected the 2 pins of the oil pressure switch plug togeather and now my carb choke gets 12v with key on. I then ran a single terminal wire from the oil pressure sensor into the cab to the back of the cluster PIN 5 on the 18 PIN instrument cluster. Oil pressure gauge will peg past 60 aka 3 o clock position when not hooked to sensor. Will show 0 when grounded or hooked to oil pressure sensor and engine off.
The below pic is what finally helped me to get all the gauges functional. FYI the wire colors sometimes vary between years but most of mine matched up. I followed the 1978-87 Factory Gauges column
A pick, tiny flat tip or large paper clip works great to unpin the metal pins from the connector, then bend the locking tab back up on each pin before re-inserting so it will lock into it's new positoin.
I'll have to take a pic of the finished plug but I ended up abandoning some PINS that were originally in my instrument cluster plug.
You MUST have grounds at PIN 3,8,10. If you don't have all 3 grounds then add them or else your gauges will be wonky and wierd things happen when dash lights on or turn signals.
You MUST have 12V switched power at PIN 4,6,16
My fuel gauge was pegged past Full at the 3 oclock position, I finally fixed the gauge by trying different color wires and switching between PINs 7,18. Fuel gauge needs both PINS occupied to read fuel level and display correctly on gauge.
I am also adding the large factory tach to replace the fuel gauge in the near future and adding the small fuel gauge in the lower left corner of gauge cluster. I am doing this on the cheap-ish by re-using the standard gauge cluster circuit board and housing. More to come...
Correct year for the temp sensor seems to be the most common challenge. They have discontinued the Delco sensor for my ‘75, and suggested replacements don’t have the right resistance range/profile to get a correct reading. Finally found more GM sensor info on a Corvette site and located a current sensor that is a very near match to the ‘75.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
What part number temp sensor are you using?
What does your temperature gauge look like? The standard cold and hot or does it actually have numbers 100 for cold and 250 for hot?
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Here’s what my instrument cluster plug looks like after repining it from idiot lights to gauges. This is with the large fuel gauge next to Speedo and volts, oil pressure and coolant temperature.
Oil pressure sensor wire goes to pin 5. I had to run a new wire from the sensor to the cluster connector.
I unhooked the yellow wire in pin 13. This is your fasten belts light and mine was always on.
I abandoned a brown wire that probably was the alternator light which is not used on the gauge cluster.
The brown and tan with white stripe is your parking brake light in pin 7.
This is on a carbureted 1986 K5
TDoc
Flagstaff, Arizona
Terrell
K10, K5
All gauges are working!
I also ordered a small fuel gauge and large factory tachometer. Once that arrives I’ll post a pic.
Important note on factory tach! You must remove the metal clips that connect the circuit board of the gauge pod to the factory tach. You will destroy the factory tach if you leave these in place!
The only connections to the factory tach are at the top via the 3 flat connectors.
S - signal wire from TACH terminal on HEI distributor.
G - ground wire
P - 12v switched power
Small fuel gauge - If you are using a gauge pod that doesn’t have the wiring for small fuel gauge you can just wire it manually to the back of the gauge.
3 wires -
2 wires that were originally on your instrument cluster connector can be unpinned and , spliced to extension wires and manually connected to the left and right terminals of the small fuel gauge. If the gauge reads incorrectly swap left and right wires and make sure ground is connected.The bottom terminal of the small fuel gauge is ground.
This video does a good job of showing you what I tried to explain above for adding factory tach and small fuel gauge.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Literally just found this! It's so cool lol, I really like the low warning light option. Maybe yall knew about this thing but I didn't
solancodad
