81-87 body molding
ChuckN
Bellinham, WA
Chad
I'll need to replace the side molding on my '81- it's a Scottsdale and the correct molding would be the black center/silver outer strips. I'm not super attached to keeping it model correct. Which one do you prefer, the black or all chrome/silver, and why? Thanks in advance.
WFO
Texas Panhandle
I used the 3M black with chrome edges on mine. It matches the bed corner metal pieces that were still good.
Here's some like it, but when I bought mine about 4 years ago, it was quite a bit cheaper.
I used some 3M primer too.
Keith Seymore
Motor City
Keith Seymore
4.3L
Mine's a Scottsdale so that I could get the vinyl flooring but opt up to a "Silverado" appearance on the outside.
B85 gets you the Silver side trim and V22 for the quad headlight grille.
K
ChuckN
Bellinham, WA
Chad
K
That’s beautiful!
Cyrillious
Toronto
Cyril
K10 Suburban
Chrome/silver if the other accents on the truck matches the strips
ChuckN
Bellinham, WA
Chad
I think that, after looking at others, I'm going to go the full chrome. It already has the chrome wheel arch trim, and rather than cover up the drilled holes for the bed rails, I'm going to get another set (not sure if they're chrome or brushed aluminum) but I think that will fit the truck a little better.
Cyrillious
Toronto
Cyril
K10 Suburban
Be cool to see before and after pictures once you're done. Hopefully the trim should be reasonable to find if you're on a budget
ChuckN
Bellinham, WA
Chad
Absolutely. I'm also going to mess around with doing some time lapse video with my GoPro. My buddy is a real pro at doing that kind of stuff with his- he does mountain bike trail maintenance, and he does time lapse stuff and it's really cool to see the before and after using that method.
fatblazer1973
North Carolina
Evan
K5 Blazer
I am working on a 1984 right now. Does any have the precut moldings any more or is all just the rolls?
3 Ton
Pacific Northwet
Fred
1978-79 78 body, 79 gearing
K-15 Suburban
We just go to LMC dot company
Zelph
Nevada
ksSD
