Front shackle bushings
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I'm looking to replace my front shackle bushings on my 86 k10. Does anybody have of the correct part number that's required? I put new spring eye bushings, Prothane brand, and the shackles don't line up evenly. The spring bushings are a bit wider than the stock shackle bushing.
Zelph
Nevada
Shackle upgrade. Comes with shackle plates and bushings/hardware.
This kit is for the stock hanger. The FUSH kit is good while you’re doing the shackles but does add into the costs.
I think you were asking about the front spring, rear shackle bushings?
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I already have the heavy-duty shackle plates, and the spring eye bushings. I just need the correct width frame bushings to line up the shackle plates evenly. I ordered some energy suspension bushings, but they were not as wide as the spring bushings. I'll post up some pictures later today, I appreciate the the link
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
They have all the bushings. What springs do you have
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I did, twice. I was sent the exact size OEM bushings. I need some bushings with more width than OEM.
JGV66
New york
Joe
I just installed the heavy-duty kit from off road designs. they ae greaseable Kevlar bushings
its a great design. just give them a call and tell them which springs you have they'll set you right up.
thermo44
