Holley street warrior 600cfm for sbc 355?
Ryanbrown36
Ontario, Canada
Ryan
c1500
Any opinions on these Holley 0-80457s carbs I have a mild built sbc 355 with a
Magnum cam
Sealed power flat tops
Polished crank
Comp cams heavy duty roller rockers, lifters, valve springs ect
Proformer RPM an intake, rebuilt 882 heads. It’s going to be my daily driver and looking for my best option for a carb, I found a good deal on the Holley and wondering if that’s a good parring for this motor/my needs.
It’s a vacuum secondary, electric choke 600cfm
Thanks in advance
3 Ton
Pacific Northwet
Fred
1978-79 78 body, 79 gearing
K-15 Suburban
The best crap China can make.
Rebuild an old one.
Rustisbest
Tennessee
6.1762844 liters
For a daily driver the electric chokes on that line of carbs suck. Quick Fuels use the same and i think the Brawler line does too.
They eliminated the vacuum chamber and mechanism that cracks the choke plate open when it fires and just notched the choke plate instead. They got rid of the vent too so the coil heats up too fast. Under a minute and the choke plate is fully open. Adjust it to where it stays on long enough and it winds up being too much. No real in between.
Look into the "classic" line (1850) or get one with a manual choke in my opinion
MikeB
The 80457 is a decent carb. I bought a refurbished one (which was essentially new) many years ago from Holley's eBay store. The engine was a 350 with Ramjet cam and Vortec heads, so essentially a Ramjet 350 with a carb. Manifold was a Holley Street Warrior.
Anyway, I fired it up, set idle mixture and idle speed, and was done. No stumbles or bogs. I did end up going from the stock 6.5 power valve to an 8.5 because the engine made around 18" manifold vacuum. The only thing I didn't like was the fuel inlet being on the driver's side. Holley also sells a 80458 carb with dual inlets on the passenger side. All specs are the same. I suggest getting the SA version (aluminum) instead of the S version.
As an alternative, this QuickFuel Slayer series carb is more tunable and uses Holley jets, power valves, and air bleeds.
That engine of mine went into an 82 SWB C10.
Ryanbrown36
Ontario, Canada
Ryan
c1500
Thank you for the input, I did notice the drivers side inlet which isn’t the biggest deal but is definitely inconvenient for making things look neat and clean
Ryanbrown36
Ontario, Canada
Ryan
c1500
I ended up buying the carb anyway due to the steal of a price I got it for, so will see how it preforms, worst case I can sell it for at least what I paid and can go with one of the other options mentioned
(At least it looks good on there lol)
Rustisbest
Tennessee
6.1762844 liters
That one had the old style choke that works like they're supposed to. Sometime in the last couple years they have switched to the cheap ones.
Rustisbest
Tennessee
6.1762844 liters
Still has the gold zinc linkage so it's old stock and probably has the good choke too.
Ryanbrown36
Ontario, Canada
Ryan
c1500
Well that’s good news! Will have to see how it works out, doesn’t need to be a crazy hot rod anyway just want a good runner with a little bit of pep to it when wanted
MikeB
I'm not a fan of electric chokes at all. I think the best-ever were the stock ones from the 60s, where they were controlled by intake manifold crossover heat. I'm really amazed that electric chokes don't burn out, because the canisters sure do get hot! I'd go with manual chokes, but all the latest cables suck. Nothing like good ole factory cables.
Rustisbest
Tennessee
6.1762844 liters
The castings might be. But they're assembled in Bowling Green
MikeB
Wow, that's good to hear. I assumed Holley carb manufacturing had gone overseas, like their Weiand intake manifolds did many years ago. I bought one that was the worst looking manifold I've ever seen. To Holley's credit, they sent me another one, and didn't even ask for a return.
I hear that Edelbrock carbs are being assembled in North Carolina, but I don't know where the casting is done. From what I understand, they are still operating their foundry in Southern CA, even though the company HQ is now in Olive Branch, MS, just south of Memphis. Unfortunately, they are owned by a private equity firm, which is like making a deal with the devil.
Greg H
