mxer147
Colorado
Jack
k20
Still a twenty footer, two tone paint is a lot of extra effort!
Strick
Dunn, NC
Harold
C20 Crew
Speaking of which, does anyone have a body lift they've removed and don't need anymore? I need the front cushions in particular but I could use all four cab cushions.
I have the radiator mount bushings but only 3 cab lift pucks. When I removed the cab from the body-lifted k30, there was one rusty bolt that just would not release the puck. You're welcome to them if you'll send me a box.
HS
Ajax19
Socal
Ajax
Yup broke a hard line on the 75 so I got a roll of 3/16 brake line and some fresh fittings
Ajax19
Socal
Ajax
Anyone else get sidetracked on something, I like to call them sidequests making a cup holder while I wait on more parts I'm only $2.50 in it for the cups and like making junk from different junk so here it is lol
mxer147
Colorado
Jack
k20
Color changed the emblem, gonna add some orange as well when I get to painting the rest of the fenders and tailgates. I used a disposable plastic eye dropper to move the left over paint from my spray gun disposable cup.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
I have dual Magnaflows on The '87 and they sound very similar to the Thrush Turbo Mufflers we had on Dad's '77 GMC back in the very early '80s. I don't love them but I do like them.
Did you put on dual cats as well before mufflers? I'm wondering if we could just do dual cats and no mufflers with 2.5" pipe. :)
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
So, you cleaned up and are going to repaint?
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Very creative. Love it.
mxer147
Colorado
Jack
k20
I’m planning to do something with the hump similarly but still haven’t thought it out completely yet.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Wired an indicator light into the electric fan circuit to show me when the radiator fans were energized. Ended up making a mounting bracket out of a left over piece of aluminum angle and painting to match. The light appears much brighter in the photo than it really is.
Did something similar years ago to my 57 Chevy, only wired the fan circuit into the unused “GEN” light in the instrument panel. Just like knowing when the fans are on.
Looks like I need to get gas. Again. ;)
I already repainted those parts in the picture. The white used to be the dull greenish-yellow GM color.
I zoomed in. Clean, looks good.
mxer147
Colorado
Jack
k20
Thanks, actually looks much better than the pictures. A little bit of paint spilled over the edge which I used a razor blade to easily remove.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Send a pic when on the truck. The final detail... ;) :)
TRKTA84
