Ac liquid condenser line
erv1994
Los Angeles
Estevan
Can’t seem to find this line anywhere online. The ac delco replacement part (15-33072) has an extra opening that I don’t need. Anyone have an extra one laying around for sale?
1986 c10 5.0
erv1994
Los Angeles
Estevan
Forgot to mention, reason I’m looking for a replacement is because the shrader valve is stripped and cannot be removed, it just keeps spinning. I was in the process of converting to r134a
fast 99
Spokane, Washington
Just looked at my K20 I purchased same line you need last year. They had the right one then but not now. Old one I replaced was leaking at the evaporator and still does with the new line. So the line is probably ok. Might have the old one somewhere if you run out of options.
erv1994
Los Angeles
Estevan
Thank you. I ended up purchasing the one with the extra port. I was reading that it is possible to plug it up with a pipe fitting. If that fails I’ll send you a PM. Appreciate it
fast 99
Spokane, Washington
Outlet is for rear ac. Might be able to weld it shut.
Tonimus
Phoenix
Tony
C10 Suburban
Along the same lines as fast 99, I'd solder or braze in something and never need to worry about it.
2manysquares2care
