What will cause this to happen in a 208 Transfer Case (Pic Inside)
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
My speedo went out. I bought a new gear and it failed after a few miles. I put my finger in the speedo hole
and could feel the plastic melted/shaved up. I pulled the T/C cone off and the gear is chewed up on one end.
Is this normal. its almost like there was no oil in the rear part. Im sure there must have because when I pulled
the cone off, oil came out.
What does the driven gear look like?
vr1967
Mississippi
Virgil
k1500
6.2L turbo
Make sure your speedo cable isn’t binding, lube it. I’ve been able to pull the center out of some and smear grease on it and reinstall, make sure it turns easily. Check the driven gear as mentioned. You should be able to turn that drive gear around and reuse, as it doesn’t look bad. The drive gears are getting hard to find, the driven are still common.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Yall wont believe this, Ill post a update tomorrow with pic's! :cheers:
Robert Bare
MT
Robert
k20
Binding cable, binding ratio adapter.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
My bad everyone, Ill get pics up tonite. Been stupid busy
dusterdude
US
mark
gmc c15
Did he have a weather event like fed ex does?
84slammer
