Truck82
- Nov 2, 2024
- Alderton
- Christopher
- c20
Ok, so I ordered this nice set of valve covers on a kinda last minute order from LMC. Two Questions.
One, can I fill oil from this PCV/breather hole? (See picture below)
Two, if not, how would I go about getting an oil fill hole cut for a cap? Is this something I can do or is it even possible?
Are these valve covers only for the older engines with the filler tube up in the front of the intake?
Ok, so that was more than just two questions but any thoughts and knowledge on the subject will be much appreciated!
Thank you in advance!
