Wheel Opening Moldings
Beercelo
Tucson
Raul
I bought the wheel moldings from LMC and they have this weird ridge and a black stripe on em. Not what I was expecting, I thought they'd be all-aluminum and didn't expect them to have this stripe on them. Did a quick google search for pics and looks like a lotta trucks have them with this black stripe, is that how all of them come? Person from LMC I spoke to on the phone sounded kinda clueless Thanks
Redfish
Prairieville, LA
Andrew
V1500
That is exactly how they came from the factory. The plain chrome ones were aftermarket.
I ordered a full set from LMC and they were surprisingly almost an exact match for the OE set I took off.
Yes, that's what most of the trucks had for wheel arch moldings.
However, '77 trucks had yellow instead of black. And the bigger however- '89-'91 K5's and Suburbans had smooth wheel arch moldings. As far as I know, they are not reproduced.
while this is a cab , they looked like this right?(for 77?)
Yep, that same mustard color was on the wheel arch moldings.
Auburn, Washington
Yep, 77 only year with the mustard trim
And curiously enough you can now buy full sets of ‘77 yellow trim.
But the only place I’ve found sells for like $1200-1300 for a full set. Whole truck not just the wheels.
They want that much for black stripe too so must be “OE quality” not the cheap tin repop parts.
Not a good value imo unless a guy is doing a nuts n bolts resto or super high $ resto mod.
When I get to it I’m going to have the right color vinyl cut and just pin stripe over a black set. Think I can get it installed quicker than $1000 worth of my own labor.
Where are those from? There's a place asking $1200 for regular old wheel well trims?? Holy cow
legopnuematic
Licensed Junk Dealer
MO
Spencer
Sounds like Mar-K with those prices.
That's for an entire trim set, correct?
84GMCSierra
Central Arizona
C2500
Nice truck!!! Perfect height, and color.
BadBowtie
North Texas
Jon
Chevrolet
5.0L
Actually, the 1989-91 Blazer, Jimmy, Suburban, and crewcab trucks had a solid aluminum wheel well opening molding without a ridge in the middle. :waytogo:
square-up
