Identify wiring & 3 prone connector, located under driver side dash
beardogc20
Danmark
oliver
Can someone help identify what this connector could be used for?
I recently purchased a 1976 C20 scottsdale. The wire starts from the fuse box (15a) then continues to a online fuse and ends with a 3 prone connector. From connector a ground wire (not connected)
Thanks
legopnuematic
Licensed Junk Dealer
MO
Spencer
CB radio or similar power cable.
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
Yup, Uniden CB power cord. Fits quite a few of the older models.
What was the third terminal ever used for? I've only ever seen two wires in them, power and ground of course.
Radiohead
MCMLXXIX
Not sure Bucket, I've only seen two wires as well. Maybe a polarity scheme?
Tonimus
Phoenix
Tony
C10 Suburban
The third pin, when used, was for ignition power. Battery/Ignition/Ground in varying order, almost always with the ground pin on the single side, IIRC.
KIMBALLD
