Spark plug foul up
martingmc86
california
martin
gmc sierra 1500
v8 5.0
O2 voltage should be constantly varying back and forth between 0.1v and 0.9v as the computer constantly adjusts fuel. high volts is rich and it pulls fuel (fuel trims will be below 128). low voltage is lean and it adds fuel (fuel trims will be above 128). ideal AFR is around 0.5v, but it will never sit around 0.5v for long.
are you having oil consumption?
might post some pics of the plugs after theys are fouled.
martingmc86
california
martin
gmc sierra 1500
v8 5.0
See if your timing actually advances,no advance will foul plugs. Monitor O2 sensor voltage with a multimeter,postcresults. O2 sensor has to be hot to work so monitor hot.
Hello
martingmc86
california
martin
gmc sierra 1500
v8 5.0
Hi! So does your timing advance? Are you burning oil?
To be honest, about four months ago, I replaced the valve guide gasket seals, but I have not noticed oil consumption on the dipstick
So third time asking,does your timing advance?
martingmc86
california
martin
gmc sierra 1500
v8 5.0
So I checked the timing with the ESC connected and it’s showing 32° and with the ESC disconnected it’s showing a 11°
While the ESC was connected, I did rabbit up and the timing did move from my point of view
mattmattmatt
