- Oct 13, 2016
- Northern Virginia
- Bruce
- K25 Camper Special TH350 NP203
I have only seen the 11,000 GVW rating on a C30 or K30, and I think it was a 4 door crew cab. Someone has done some swapping of something if your truck is only a heavy half.
Based on the hub caps, you do not seem to have 8 lug wheels or a 14 bolt rear axle, so it’s only a half ton. Maybe they just added the HD rear springs to a half ton. The Trailer Special badges probably came from some other truck.
