- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
Some of you are probably rolling your eyes (Grit dog I see you lol) But I going to be removing the good things from my old C1500 (1996 C1500 silverado trim) including the Vortec and the 4l60e (I even have an extra 4l60e for it)
Of the things left after removing that stuff, I want to make a truck bed trailer from the box and rear frame, because its in good enough shape. However, its got a 3.73 open 10 bolt, and the large capacity gas tank for the gmt400s, and Id rather not make a trailer that I need to then swap in different parts to make use of those good parts
I want to use the bed for my truck bed trailer which I use for garbage hauling, you all may have seen me talk about it. Its sitting on a 1976 C20 rear frame. If I free up the bed on it, and put a gmt400 bed on it, I dont have to make another trailer that I frankly dont need that much, but I can make use of the bed liner (plastic) and thats its a beat up bed already, and put it to good use for my garbage needs. plastic liner will allow the contents to slip out easily, helping me with when I take it in.
Is it fairly simple to put the box onto the square frame?
If i researched right, this is a gmt400 frame in the rear
Other than the notch for lowering, this is a square body frame
They should both be long bed frames.
It appears the gmt400 uses a flatter frame than a square, and they use hidden fasteners not visible from the top (Not sure how they do it)
But if anyone knows if its easy enough or not, let me know. I have a lot of time to do anything, no time crunch
