Brake light issue I can't get smart to
papapavs1
wisconsin
avery
Hello, '78 K25, and I don't have brake lights anymore. I did a quite a bit of work to the truck, but a few things that may be of interest are: replaced the ignition switch, pulled the bed off for a while to paint it, and had the steering wheel pulled to replace ignition lock cylinder. Went back together and now theres no brake lights. All other lights and signals work. I tested that I had 12v to the brake switch, which I did. Tested continuity on the switch, which I had with the pedal pressed, and opened the circuit with the pedal not pressed. Checked at the block on the firewall, and the green and yellow wires each had 12v on them with the brake applied, down to zero when not applied. But then when I go back to the plug at the back of the box, I get 0v on either wire with the brake applied. I put a signal on, and I get 12v on the corresponding wire, so I know the wires aren't bad. What am I missing here?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Are you sure the wires aren't bad? Sounds like a pinched wire.
papapavs1
wisconsin
avery
Signals work fine, which is the same wire as the brakes so I don't think theres a pinched wire. I also looked and didn't see anything wrong
Did you mess with the turnsignal switch,at all? It breaks contact to the brake lights when the turn signal is on.
papapavs1
wisconsin
avery
I had to pull it out of place and reinstall it for the lock cylinder. I don't have any brake lights even when not signaling either. I checked the block of terminals on the firewall and I had voltage to both of the signal wires with the brake applied, and I believe that is farther down the line than the signal switch
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
If I remember correctly brakes and signals are not the same wire. I may be wrong though.
Jgonick
West Texas
Joel
yep- same wire (DK GRN & YELL) from lights to turn switch- Turn signal switch feeds brake wires from different sources depending on braking (WHT), hazards (BRN), or turn signal (PPL). If signals/ hazards work back lights, I would be looking at brake switch (orange & white wires) and turn signal switch. Might not be getting enough amps -bad connection (maybe??)
Edited to make it clearer-
Jgonick
West Texas
Joel
Wiring diagram of taillights
creamsicle76
