Dome light upgrade
hey mister
North Coast
Marty
Has anyone ever made a replacement dome light housing? Maybe with LEDs?
And I don't mean one of those out of a catelog.
I mean, one that you made from scratch?
Wood, plastic, metal, doesn't matter.
87chevy_com
Clint
L83
I bought some LED SMD boards and they worked out amazing. cheap too
L.E.D. dome light upgrade project - check - The 1947 - Present Chevrolet & GMC Truck Message Board Network
L.E.D. dome light upgrade project - check The 1973 - 1987 Chevrolet & GMC Squarebody Pickups Message Board
67-72chevytrucks.com
I also bent up a light gauge sheet metal bracket that bolted to the bottom of the dash frame where the OE lamp was.. wired the SMD light board with the tape to it and worked out amazing!. Maybe better to put 2 instead of 1.... one on each side of the floor board instead of the OE center
Lately I've just been switching out the standard bulbs with direct replacement LED bulbs. Not so much for a lighting improvement, but mostly to reduce the battery drain when the interior lights are on. I have a habit of pulling up to the shop or into a buddy's place, getting out and simply leaving the door open. Not sure why, I just do.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
We used the LED upgrade for dome and left original foot well lights original since I could not find direct replacement LED to fit those sockets. We did add a floor well LED under dash over hump and it totally illuminated the floor and just tapped the power from stock well lights.
Randy and E
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
That, plus they run much cooler than those little tube bulbs. I've nearly lost my fingerprints on those things a few times and they melt the plastic lamp housings.
Oldbear42
Linden, Alberta, Canada
Shaine
C20 LWB Scottsdale
I switched all the interior lights to LED, including the dash lights. They are brighter and run cooler while using less energy, and I'm happy with the results. My only issue was that the dome light in my 81 C20 is a two-terminal bulb (one positive, one negative—it doesn't ground through the housing), so I had to clock the LED bulb correctly, or it wouldn't work.
Bloodhound1981
MA
Rusty
C-10
I installed this LED light as my interior light, it is what is installed as an aftermarket light in police cars. It is also dual color so it can be red for night time. I also put LED bulbs for under the dash to match the white color.
Old Guy Bill
KY
Bill
Same here, been putting the whole interior back together the last few weeks.
crew
