84GMCSierra
- Feb 26, 2023
- Central Arizona
- Paul
- C2500
Is there a way to find out the tooth count on an original flywheel for an 84 Sierra 2500, with a 250 and TH400? I could get under the truck, Mark one tooth and rotate the engine counting the teeth but I'm looking for an easier way if there is one. Engine has been changed in the past and I'm having starter problems and the teeth on the flywheel are worn. Thanks
