TommyGuns
- Jun 2, 2024
- Tennessee
- Thomas
- K10
What is this part, and can I buy a replacement if I modify the original? It is not the PCV filter, I have that installed on the opposite side of the air cleaner and I don't use it anyway.
I am installing a Pro Flo 4 system and I'm looking for a spot to put the air temp sensor. I have identified this fitting on an OEM air cleaner I bought a while back, that would be a perfect spot to mount the sensor. I do not want to drill another hole into the air cleaner. However, I also do not want to modify the original plastic fitting if it is irreplaceable. I think it's the part of the PCV system but I don't need it. My current PCV setup is the throttle body PCV vacuum to driver valve cover, with a filter on the passenger valve cover. The light truck service manual, truck owners manual and Google have failed me.
