Bulb with black plastic wire
asjt3
arlington VA
alex
V1500
Folks, on the back of the instrument cluster there’s a bulb with what seems to be a black solid plastic stiff wire attached. It’s black with a green stripe, anybody know what this is for? Doesn’t seem to be electrical in nature?
1990 chev suburban V1500
dd1990
Ventura CA
Suburban 1500
That wire is a fiber optic line, sends light from bulb on dash cluster to the ash tray
Turbo4whl
Downingtown, PA
Wayne
If it is on the right side of the instrument cluster, it is fiber optic line to light up the ashtray. On the left side it lights up the wiper switch (older model than the '90)
Early squares had a fiber optic ribbon to light up the wiper switch.
Turbo4whl
Downingtown, PA
Wayne
I was slow to respond, David has it ^^^
asjt3
arlington VA
alex
V1500
Wow that’s interesting thanks for the replies. Now I’m confused though, because there is also a free hanging bulb that I thought plugs into the ashtray like on the GMT400s. Is it possible this dash cluster is from another year or is the free hanging bulb for something else?
gmbellew
Kansas city
glen
suburban 1500
might be for the HVAC controls if it has a bulb attached and doesn't have a spot in the cluster.
asjt3
arlington VA
alex
V1500
I found where the fiber line plugs in above the ashtray. Very interesting. I’ll have to figure out whether this bulb plugs into the HVAC cluster.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
It goes into the very top far right of the gauge cluster.
Moe H
