What is this sensor?
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
This was in I believe the driver side head, the other side had a knock sensor in it about similar location if I remember correctly
. This looks like a coolant temp sensor to me but the plug is not like anything I can find online. So is that what it is? I can't go look at the truck because the engine and heads are at a machine shop. Thanks
OH and the truck is a 87 350 TBI engine.
F-64
nyc
mike
R10 lwb
5.7 tbi stock
Octane
Atlanta
Eddie
My truck has one exactly like it.
Temp gauge sensor. 1977 k10 350cid
78C10BigTen
pennsylvannia
C10 BIG TEN
My 78 is the same temp sensor too.
CorvairGeek
Boise
C20 Scottsdale
292 L6, T400
If you look carefully at the corresponding connector on the wiring harness, many GMs could plug into both the button style connector (like shown) by plugging on to the sensor perpendicular (with the little half circle cut out in the connector), or plugging straight on to a spade style connector. I have theorized this was done to make them more universal, and to distinguish between gauge and warning light sending units, but that is just my anecdotal observation.
redneck_reed78
Spring Valley WI
Braden
R30, Suburban
I think you're on to something @CorvairGeek and like the rest of you suggests it appears the sensor is an earlier style.
With no definitive answer, instead of causing more headaches I'm gonna stick with the old saying "If it ain't broke don't fix it"
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
these are all temp sensors with different terminals. the second one is a nail head design found on earlier chevys . the knock sensor should be in the bottom of the block and much bigger.
Joshua Keith
Memphis
Joshua
Does it work? I’ll buy that from ya if you don’t want it.
WarlVlachine
WI
Robert
Temp sensor for sure, just like everyone said. Green wire if I remember correctly, the connector slides on sideways kind of. looks just like a normal female spade. I've only ever seen the one that came in my 86'.
Ken B
indiana
ken
this picture enlightened me, my sensor connection point looked like a hollow "pipe". looking at this picture i can now tell mine is a nail head that the "head" was knocked off.
old thread still spreading information
thanks
BlackandBlue
