EvilGenius
- May 12, 2016
- Metro Detroit
- Darien
- K10
I'm looking for advice on things to examine on my 700R4 that could lead to shifting right from 1st to 3rd gear. The 700R4 in my truck was shifting through all 4 gears not long ago, but I recently ran it a little with low fluid (10-15 miles total). Since topping it back off I seem to skip 2nd gear and shift into 3rd around 25-30 mph and engine rpms are pretty high. Based on some internet searching there is a chance I didn't do any major damage. Any tips on what exactly to look at if I get the pan off or should I look at anything behind the servo cover? I've never been into one of these before so any tips are appreciated.
As for how I ran it low on fluid... I dropped the transfer case to change out the seals and when I put it back in I forgot to check the fluid level in the transmission. I believe that fluid had accumulated in the adapter between the t case and trans. When I dropped the t case all that fluid came out and then that cavity refilled from the transmission, which left it low on fluid.
