Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
Seen alot of how-to's here with the idea of cleaning and sealing the inside leak-prone areas of the cowl. A pig in a poke with whatever sealer you use. So I'm about at that point and was wondering.....when someone says "open up the cowl" - exactly what are they referring to? Cutting the grill off and re-welding it? (not happening) My cowl is 100% cleared and raw steel - needs sealed up. I can stick the paint gun down in between the grids but thats going to make a mess. Cant see a seam sealer caulk tube fitting very well either.
Just wondered what the secret is to getting in there and seam sealing/painting/whatever the whole thing?
Thanks fellas.
Thanks fellas.
