TubeTruck
- Sep 4, 2019
- East TN
- Denis
- Suburban K10
- LQ9
Fig 8. I bought the long input from ORD and rebuilt the t-case. Yup, got the spacers on the outside of the bearings, everything spins good, not too much play.Round pattern 205? Or did you modify a figure 8 to have the long input? I have a stock 205 Figure 8 with the short input as it originally had a TH400 in front of it. I'm using the stock adapter with a Northwest Fab adapter plate and cut down a 2wd output shaft to fit the required 4-7/8" length. I don't think I've ever seen a 205 input shaft go that for onto a 4L80 output shaft to have stripped it that close to the trans.
Now, for the tranny rebuild, I bought a "cut to fit" forged tailshaft from ATI Racing and swapped the t-case to a short input. After I cut it, it's about 1/8" from bottoming out on the short input.
