Fuel Gauge Woes
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Thought I had my fuel gauge working because I made a connection between the gauge and tank wire and it went from 3 o’clock to 3/8 tank, but would only read 1/2 tank when filled.
Heard that it's likely this little resistor that's gone bad on the back of the fuel gauge.
Tested the resistance (should be 90 apparently) and got this:
Maybe a new resistor will fix the gauge?
dh-jp
Dusty
GMC C1500 Sierra Classic
We’re you able to change the resistor? If so, did this solve your issue?
OurDually
