454 build, which pistons to get to 9:1?
txaggie
austin texas
kris
suburban C20
Howdy all,
My 454 went to the machine shop today for a block dip, new bearings, and valve jobs on the heads.
I’m adding in this Howard’s hydraulic roller cam and lifters, matching springs, headers, rpm air gap intake, Holley sniper, 2.5” x pipe exhaust. My question is should I do new pistons as well? This cam is geared for 1400-4900 rpm.
txaggie
austin texas
kris
suburban C20
ChuckN
Bellinham, WA
Chad
Maybe the shop that helped with the block could help?
Short of that, there’s tons of compression ratio calculators online that you can use. https://butlerperformance.com/n-12872-compression-calculator.html
You could look up what chamber size you have, what head gasket and then plug it into the calculator- play with it a little and then find the piston dome/dish that fits your needs. Don’t forget to factor in the cc’s for the valve reliefs as well- piston manufacturers will list how much volume they are. Have fun!
Confused
Angier NC
George
That is a mild cam and should work even with the stock compression. That being said it wouldn't hurt to deck the block a little (if for no other reason than to make sure it is flat and square) and have them mill the heads a little as well. Thin head gasket and it all adds up.
I would have them do a hone on the cylinders and new rings as well.
yevgenievich
Place
Name
Year
Model
Size
If trying to not mess with balance much, need to get weight of current pistons first. Then can start searching for different pistons. Is this tbi or vortec block?
txaggie
austin texas
kris
suburban C20
nvrenuf
Mobile, Al.
I’m running pistons with a 230cc dome, my machine shop said I should be about 9.4 comp (781 heads).
yevgenievich
Place
Name
Year
Model
Size
I was way off on which block. I am running flat top pistons with angle milled heads and mls gasket for 8.9:1.
txaggie
austin texas
kris
suburban C20
What pistons are you running? Peanut port heads?
txaggie
austin texas
kris
suburban C20
Looking to get 8.5-9:1
Do you think this would be more bang for buck than just changing to a flat top overall? These are what my pistons look like now:
Confused
Angier NC
George
If your pistons and bore are good no reason to change them IMO. If they are out of spec then a dome pistons that puts you at 9.0-9.5-1 will help power everywhere.
yevgenievich
Place
Name
Year
Model
Size
I had rotating assembly balanced with new flat top pistons and aftermarket heads angle milled to about 108cc.
Vortec 96-99 bbc heads have 97 to 100cc chambers and give a bump in compression. On other motor I am planning to try finding domed pistons with similar to stock weight to reduce balancing issues.
nattursch77
