gm nv4500
south456
eagle id
trace
k20
hey guys i have been considering putting a 90s nv4500 in my 1985 square so it will have overdrive and i can actually drive it on the freeway, has anyone done this and can shed some light on how difficult it is actually going to be. i know i will have to get a adapter to put my np205 on the back of it and i know the frogger arm is on the passenger side not the drivers but what else will there be?
SquareRoot
First things first. What trans and t-case do you currently have? I know someone who is familiar with this swap.
south456
eagle id
trace
k20
I currently have a sm465 tranny and np205 transfer case
SquareRoot
Is the truck currently using the 465? Just clarifying if the truck originally had a manual or auto. Since K20's didn't come with a 205 in 85 I'll assume it's not original either. Is the 205 the figure 8 or round pattern version? There's a reason I'm asking these questions, hang with me.
85K304SPD
Las Cruces, NM
Richard
Following... My '85 K30 has 465/205. Overdrive would be awesome!!
south456
eagle id
trace
k20
The truck currently has a 465 it was stock manual and i swapped in a 205
SquareRoot
Good news is your 90% there. You need the correct bell housing. You can modify yours or buy the Advance Adapter one. Your existing member will work. Mine bolted into the same holes on the frame. You need a 4500 specific trans mount. You will need a shifter and bracket of some sort to work the t case. Now's a perfect time to swap it to a twin shift setup. ORD and others have shifters and brackets specifically for this application. Also, put a fixed yoke on the output shaft and get the shaft adjusted if needed. It will need a slip joint put in it regardless. I love my setup. It's worth the effort.
south456
eagle id
trace
k20
Cool! Thank you for your help.
Jester67
USA
Chevy
I don't want to hijack this, but would it be the same if you had a 208 Tcase?
Obullard74
