Flip kit?
blazntn
TN
Bead
Blazer 2wd
I ordered a flip kit for my 79 blazer. However it doesn’t fit. I have a 12 bolt rearmed, I am assuming that is the problem. Any body have any suggestions? Companies that make one for a 12 bolt?
Bennyt
Surprise
Ben
I usually make my own. Usually about $20 for leaf spring mounts and an hour to weld them on. If you can't do it, any suspension shop should be able to.
blazntn
TN
Bead
Blazer 2wd
That would be awesome! But I am not a welder!!
mlsceo
Kingsburg California
Manuel
Who did you order from? Is your 12 bolt factory stock? Try LMC, I've had good luck with them. Just make sure you specify parts for a Blazer.
What doesn't fit? The axle tubes too large? Who's kit is it?
Obullard74
