scape
- Oct 2, 2023
- Springfield, MO
- Shannon
- C10
- LS
I bought an 85 GMC C25 and am in the process of swapping it all over to a SWB C15 frame. Truck has a 350 "M" with THM400 all original.
Questions I have on engine wiring.
1. I found four wires close to the alternator that were previously cut. The look pink/black x2 and 2 solid black wires. Smog (A.I.R.) had been removed prior. I assume these wires went to something on the emissions but would like to know.
2. Blue wire from engine harness. I believe this goes to electric choke on the carb. Not sure.
3. Pink/Black wire that comes out of harness next to blue wire - where does it go?
Thanks!
Thanks!
