Better illumination of gauge cluster possible?
Andreas Wickman
Sweden
Andreas
The illumination of mine gauges are very poor (C20 1983). Does anyone know if it is stronger bulbs for gauge cluster available? Any LED option?
Best regards from a cold Sweden.
Scott91370
Burleson, Tx
Scott
Sierra1500
LED will work but may not be dimmable (have to get the right kind for this). If they do not come one they're installed 180 degrees out - they are polarity dependant.
Another trick is to pull the gauges completely apart and paint the housing (the yellowish plastic piece) with some chrome paint. That with LEDs seems to work very well. I have a buddy that did this in his '73 and loves it
fast 99
Spokane, Washington
Tried LED in a cluster, very disappointed. Didn't use chrome paint that is a good idea.
GTX63
Tennessee
Ty
I bought some leds off ebay or amazon. I bought multiple packs for each truck as I start tearing into dashes.
Most of them do not dim, so there is that. All of the ones I have used "Superbrite" might be the brand, have worked well.
The factory lights are akin to holding a bic lighter next to the gauge, and they were like that when new too.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Change the bulbs out to 168’s they are a watts or 2 brighter than the originals
Yes. #194 bulbs are stock, they're 2 candlepower. #168 is 3 candlepower so half again as bright. Also a good upgrade for the side markers and license lights. Don't get #161 as they are only 1 candlepower.
I wasn’t sure the #168 bulbs would help that much.
I decided to repaint the metal back of the cluster white, and then ordered new dimmable led bulbs from an online store (Super-bright LEDs, IIRC). They are dimmable, but not exactly like an incandescent. They dim to about 1/2 brightness, and then suddenly go nearly completely off. However, overall it works really well.
I also bought a red led for the brake warning light, and green leds for the turn signals indicators.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
These are dimmable, excellent
Bullet Bob
Louisiana
Robert
Any chance you have a picture at night time on full brightness. I’ve been debating swapping and may order these if they will dim
ChuckN
Bellinham, WA
Chad
I used 194 bulbs because it was the only thing in stock at the time. When I take the dash apart I’m definitely going 168, they’re just too dim.
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
Lot of stores don't have the 168 any more. We always had them, but that was because they used them more back in the day. Dad also carried many items that he used; I remember him explaining to customers about the brightness difference on the gauge clusters and backup lights/license lights.
Craig Nedrow
Washington State
K10, K20, C20
I will take a pic tonight and post it to you, but they are BRIGHT, I really like they, and they dim well
twpeasley983
